Drains
Problem for Drains
Generic problem for all Drains
Condensate pump on humidifer/ac
By toolbeltmom on Dec 09, 2008
i have a hartell auto condensate pump which this time of yearisservicing the humidifier (also drains from central air unit insummer). noticed puddles on floor, and the unit's not shutting off, butnowater was coming through the drain tubing. the fan continues torunconstantly, so i'm assuming the motor is working and there is aclogsomewhere?
Comments:
Dec 09, 2008
- thanks, i removed the pump and cleaned and tested it in the laundry sink, and it pumps, and also switches off, so it looks like the tubing might be the problem, which is nice because it's the cheapest part of the system. going out to hardware store, wish me luck!
Best Solution
posted on Dec 09, 2008
Helpful)
Ms Kat
Rank: Apprentice
Rating: 91%, 11 votes
To me it sounds like a tube is plugged so where, It also might be the switch is going bad on this unit.
Was this helpful?
Yes
No
Popular Solutions for Drains
Questions and Unsolved Problems for Drains
Answer
my tub stop will not come out. I believe it is a moen. I can unscrew the top but then nothing. There... (More)
Answer
after power is applied, the lights are lit for only a few seconds, then the power goes off in the... (More)
Answer
bad drainage smell in rooms. i need a diaram of how a stack pipe with aav's should be fitted. please... (More)
Answer
Richmond Power Vent Hot Water Heater can you reset the lockout so you can use your hot water heater
Answer
the "tropical shower tank" is badly cracked around many of the nozzles - where can I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Drains:
Top Drain Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drain Experts
Top Plumbing Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(866) 897-9936
316 2837038
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
