"Operating System not found" message
I am getting this message when I try booting. I tried other options - changing boot sequence, boot from Win98, using FIXMBR utility. The Setup does not recognize a hard disk. Before it died, it was waking up if I tried to boot after a dormancy of 2 or 3 days, but it used to be awfully slow and would eventually hang up with a blue screen. This happened after I installed a USB wireless adapter.
There is no hard drive self test feature in the BIOS. Can you pls suggest pointers to upgrade the BIOS?
Thank you!
  • 300 Answers
The operating system not found using means just that the OS isn't correctly installed or the hard drive isn't being detected by BIOS. You may want to try reseating the hard drive in the laptop.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Dec 09, 2008
Getting "operating system not found" message on start up
Restart laptop and begin pressing F8 to go to boot sequence.
Change it to boot from CD.
Also check if this CD is clean and works from other PC
Jun 08, 2012 | Dell Studio 1537 Laptop
Invailid disc
Did you reinstall windows? If not, you need to put an operating system disk in the cd drive and boot from it and reinstall windows.
If you don't get an option to Press Any Key to Boot From CD message then turn the computer off and restart it and watch the screen for which key it says to hit to Change the Boot Order or Boot Sequence. Hit that key when you see the message otherwise it will not work and you will have to reboot. This is a temporary fix that will work that this boot cycle.
If you want to make a permanent change to the boot cycle or boot sequence you have to turn the computer off then turn it on and watch for which key it says to hit to get into the Bios or System Setup. You have to hit that key when you see the message or it will not work and you'll have to start over. Once inside the Bios or System Setup got the the Boot Tab so you can change the boot order or boot sequence. Normally you want it to boot from the CD drive 1st and the Hard Drive 2nd. With this setup just make sure when you boot the computer that you don't have a music cd or movie dvd in the drive or it will try to boot from it and give you an error message.
Jun 02, 2012 | Acer Aspire 7741z
When I press F8 key and it's not giving a option to restore my computer
No bootable device means the system cannot boot from where ever you are trying to boot. If you have something in the CD Drive other than a Repair Disc or Operating System Disc remove it.
Try booting from your hard drive. Turn off the computer then turn it back on and watch the screen for which key it says to hit to Change the Boot Sequence or Boot Order. Hit that key when you see the message or you will have to start over. Select the Hard Drive as your boot device. If you get a message about an unbootable device then you will need to run the Check Disk Utility. If it boots, then you will need to make a permanent change to the Boot Sequence or Boot Order.
To make a permanent change turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup. When you see the message, hit the key otherwise you will have to reboot and start over. When the Bios or System Setup window opens tab over and Change the Boot Order or Boot Sequence and save your changes.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 27, 2012 | Dell Computers & Internet
Will not move past pre start screen/ operating system not found
Sound like you might be be booting from your hard drive or you might have a music cd or movie dvd in the CD/DvD Drive. When you turn the machine on watch the screen and see what key it says to hit to Change the Boot Sequence or Boot Order, then hit that key while the message is displayed. Select your hard drive as the boot device and then see if it boots.
If it boots you need to reboot and watch the screen again to see what key it says to hit to get into the Bios or System Setup. Once in the Bios or System Setup tab over to the Boot Sequence or Boot Order and make your cd drive the 1st Boot Device and the Hard Drive the 2nd. This will make the change permanent, whereas the change we did before is only for that boot cycle. When you boot just make sure nothing is in the CD/DvD Drive.
May 12, 2012 | Computers & Internet
Getting message telling me operating system not found
This is usually due to corrupted files on your hard drive or a problem with the cables connecting your hard drive to your computer. Try obtaining a software disc on your operating system and booting from it. This will give you repair options or an option to reinstall. There might also be a button you can press during the BIOS screen that will help repair or reinstall your OS. If this doesn't work, it is a problem inside your computer with the hardware.
Jul 29, 2011 | Samsung NF210-A02 Netbook
When I try to boot up my Compaq Presario 2500 laptop I get the following error message: PXE-E61: Media test failure, check cable Operating System not Found. I have tried changing the boot sequence in the...
Boot sequence isn't enough. You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
Jun 06, 2009 | Compaq Computers & Internet
Booting probs
go to boot sequence in the order
CD/DVD
Hard disk
others
Apr 23, 2009 | Compaq Evo N410C Notebook
Will not boot
CHeck the jumper settings of the hard drive...
is it detecting on BIOS>.
Apr 02, 2009 | Computers & Internet
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
Operating system is not found!
Try checking the boot sequence of your computer. Turn on the computer and press Del or F1 before the POST. You will see there an option for Boot Sequence. Make sure that the 1st Boot is set to your hard disk.
May 18, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
446 people viewed this question
David Payne
David Payne
