Question about Xerox Phaser 8500/DN Printer
Replacement parts??? Where can I get replacement parts for the Phaser 8500?? I need a new front access door. When you open the front cover, the latches that keep it closed are broken (one is broken). Can anyone recommend where to get a new one???
    Sergeant:
  • 236 Answers
Here is a site that sells parts. - LINK
Posted on Dec 09, 2008
I do not know how to change my printhead on my HP Officejet Pro L7580
---Make sure the printer is on, or press the Power button to turn it on. Wait for the printer to finish any warm-up diagnostics or print jobs it is performing.
---Open the access cover to the print heads. This cover may be the top cover, the front door or an ink access door on the front of the printer.
---Wait for the cartridge carriage to stop moving, making sure it is completely stationary before putting your hand in the printer. Lift up any clips or latches keeping the print heads or cartridges in place.
---Remove the old print head or ink cartridge if it is part of the cartridge, and discard it. Remove the packaging from the new print head, making sure to peel off any protective tape or twist-off protective caps.
---Insert the new print head or cartridge into the empty slot. Lower any clips or latches and make sure the print head or cartridge does not wiggle in its spot, otherwise you need to pull it out and reinsert it into the printer.
---Close the cover you opened to access the print heads and wait for the printer to calibrate the new print heads. Some printers may produce an alignment page, which you can throw away.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Apr 04, 2013 | HP Officejet Pro L7680 All-In-One Printer
MY MACHINE STOPPED FROM DOING A LOAD OF LAUNDRY, THE MACHINE WAS DONE WITH NO LIGHTS ON. I HAD TO FORCE THE DOOR OPEN AND I THINK I BROKE THE CLOSING AND OPENING SWITCH. NEED TO KNOW HOW TO REPAIR. ...
You will need to order a new door latch assembly. It likely did not unlock due to water remaining in the tub. Remove bottom panel to check pump filter for obstructions. Door latch is accessed by removing the front part of the rubber door boot. There is a small spring at the bottom of it that keeps the clamp tight around it. Remov ethe outer clamp and fold the RH side back to expose the door latch assembly. You can download the service manual at teh link below if you would like.
Service Manual
Kelly
Mar 22, 2011 | Washing Machines
How to replace head catridges.
Instructions
  1. Make sure the printer is on, or press the "Power" button to turn it on. Wait for the printer to finish any warm-up diagnostics or print jobs it is performing.
  2. Open the access cover to the print heads. This cover may be the top cover, the front door or an ink access door on the front of the printer.
  3. Wait for the cartridge carriage to stop moving, making sure it is completely stationary before putting your hand in the printer. Lift up any clips or latches keeping the print heads or cartridges in place.
  4. Remove the old print head or ink cartridge if it is part of the cartridge, and discard it. Remove the packaging from the new print head, making sure to peel off any protective tape or twist-off protective caps.
  5. Insert the new print head or cartridge into the empty slot. Lower any clips or latches and make sure the print head or cartridge does not wiggle in its spot, otherwise you need to pull it out and reinsert it into the printer.
  6. Close the cover you opened to access the print heads and wait for the printer to calibrate the new print heads. Some printers may produce an alignment page, which you can throw away.
Feb 02, 2011 | HP Office Equipment & Supplies
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer will not start. I keep getting a "dl" and an "f" signal. I assume it means door lock failure. I've tried unplugging and opening and shutting the door before restarting but it won't...
It is indeed a door lock failure. Replace the door lock/latch assembly (part number 8181700) to solve the problem.
Mar 01, 2010 | Washing Machines
Front cover of phaser 8550 won't close correctly
You can download the service manual free at ww.eserviceinfo.com
Aug 18, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 6250
There are two release latches on the Phaser 6250: A and B. If you open the front using the A latch on the front of the printer you will not see what you need! If you open the B latch on the right side of the printer you will see the orange locking sliders in your diagram #4. Move these to the unlocked position and then open up latch C. This is an orange lever inside the printer on the left, behind the fuser assembly. Once you open this you can remove the fuser.
Oct 07, 2008 | Xerox Office Equipment & Supplies
We have a Phaser 8560 Printer and we are getting the message "maintenance kit low" message. What does this mean and how do we fix it?
This will require servicing:
The maintenance kit contains a maintenance roller that keeps the surface of the Imaging Drum clean and oiled.
NOTE: Order a new maintenance kit when the Display Screen displays a message that the maintenance kit is low. Replace the kit when the Display Screen prompts you to replace the maintenance kit. Both a Standard Maintenance Kit and an Extended Maintenance Kit are available for the Phaser 8550 and 8560; however, only a Standard Maintenance Kit is available for the Phaser 8500. An Extended Maintenance Kit will not be functional with the Phaser 8500.
WARNING: The printer's interior may be hot! Do not touch the hot surfaces.
Once you have the part: instructions:
  1. Open the door on the right side of the printer.
  2. Grasp the maintenance kit (labeled A) from the maintenance kit slot and pull the kit completely out of the printer.
  3. Insert a new maintenance kit and push the kit completely into the maintenance kit slot. Follow the illustrated instructions included with the maintenance kit for full installation and disposal information.
  4. Close the door.
This will be on the right side of the printer.
This will need to be replace every 10,000 sheets of paper.
  1. Close the door.
Apr 03, 2008 | Office Equipment & Supplies
Close front cover message
Well here is what I can tell you.
Open the front cover. Staring you right in the face should be a bar code/number sticker. Look forward from that and there shoule be a small plastic tab, about a half inch long and less then the thickness of a popsicle stick. It is the front cover interlock switch actuator. It may be broken off.
Or look for the opening where that tab should slide into the machine the switch may be dislogded or broken.
Probably that tab has broken off not actuating the switch on that cover.
Dec 29, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
113 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
