Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Featherlite trimmer primer bulb
When i press the primer bulb it stays down.
  • 211 Answers
Hi
Check the hoses from primer bulb to the carb.
best regards savumihai71
Posted on Feb 12, 2009
How to restart again once it has been turned out and sit for a while. do I have to push the primer bulb to get it started again?
Depending on what your manual recommends. Generally if its been sitting longer than 30 minutes then use the primer.. If Less ten just use the normal cold start choke procedure without priming. But if you have the manual then check it.. It may state otherwise either way its not going to damage the saw.
Mar 30, 2016 | Garden
Replaced fuel lines and primer bulb ON A BOLENS LB 160 25 cc TRIMMER. Primer bulb stays in and wont pop out. it pops out after abouot 3 minutes or if I loosen the primer bulb mounting screws
Check the carburetor internal filter screen for clogging. Also the primer assembly itself maybe bad. If the primer assembly itself is bad a new carburetor is in order.
Feb 09, 2015 | Garden
The primer button on my featherlite weed eater needs replacing. How do I do this?
On your machine, it is easy. Remove the 2 large philips-head screws holding the bulb retaining ring. They are located on top, on either side of the bulb. Pull the ring off. Then, just pull the bulb out, replace it, making sure it is in the groove in the primer base assembly correctly. Then just re-install the retaining ring with the 2 screws. Don't overtighten these screws as they are going into softer metal. That is it!
Jul 14, 2011 | Garden
A relative has a weed eater featherlite 20c and thr primer bulb doesnt keep gas in it,is it supposed to?and if so what is the cause?And it want stay running unless u keep it running wide open.Why is that?
The machine is having a fuel delivery issue The purge/primer bulb PULLS fuel from the fuel tank, thru the carb and then to itself it pull any air/old fuel in the carb...and the PUSHES this mixture back to the fuel tank. There are check valves in carbs that have the bulb on them..Deteriorated fuel lines clog a screen in the carb and the ethanol in the gas works to deteriorate the fuel pump and metering diaghram in these carbs...You have to start at the tank with the fuel filter and go from there.
I'd say from the running symptons that a diaghram kit is needed for the carb...they are cheap and easily installed.
Aug 12, 2010 | Garden
Featherlite SST 25 Gas Trimmer
Clean the carburetor and replace the spark plug and air filter. Also make sure the oil/ fuel ratio is correct.
Feb 10, 2018 | Poulan WeedEater Hedge Trimmer 25cc Engine
Featherlite FL 20 fuel line assembly
1 from filter in tank to carby 2 out of carby to primer 3 from primer back to tank
Jul 06, 2009 | Garden
Featherlite fuel lines
you have a primer bulb correct?
when you push it see which part squirts the fuel OUT that is your return line the other would be the suction or filter side.
May 24, 2009 | Garden
The primer bulb doesnt retract after pressing it
hi
check the hoses at the primer bulb not to loose or broke
bye
Apr 16, 2009 | Poulan Featherlite Gas Blower, with Low...
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
677 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
