Question about HP OfficeJet 4315 All-In-One InkJet Printer
Will not connect
Have a new internet provider,now printer is reading "not connected". Have checked USB cord and it is fine. Can not find disk.
  • 60 Answers
Hi you should be able to download it from hp website have you installed any new software or hardware, have you also check to makesure its online from the printers setting
Posted on Dec 09, 2008
EFI/Mircrosoft/Boot/BCD
It's not clear what exactly you mean. Generally, you don't connect two computers together using a USB cord. You can use a "cross-over ethernet cable" to connect the network jack of one computer to another computer. This allows transferring files and/or sharing an internet connection. If you have a wireless router you can enable Windows "File and Printer Sharing" on each computer and transfer files that way. Please provide more details of what you're trying to accomplish by connecting the computers together with a USB cable, and we may be able to give you a more specific answer.
Jul 30, 2014 | E-Machines eMachines Desktop PC
No conneck to internet
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
if you have already done this
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 01, 2011 | Computers & Internet
Can't connect to internet
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the intrnet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
or if you mean that you are having problems with your internet connection
also
hope this helps
Feb 13, 2011 | Foxconn WinFast K7S741MG Motherboard for...
I can not use intarnet
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
dont forget to vote
Feb 11, 2011 | Computers & Internet
No internet network installed???
if you dont have an internet connection
hope this helps
Feb 10, 2011 | Jetway N2VIEW Motherboard
I bought the HP Deskjet 5650, but I'm not sure how to install it to my home computer.
First find the installation disk that came with your printer in the box. Install the software by placing the disk in your CDROM of your computer and then follow the instructions on the screen. when the software has finished installing, connect your printer to the computer with your USB cord and the computer will automatically do the rest.
Some operating systems already have the driver for your printer and the software is not necessary. To check and see if your computers operating system already has the necessary drivers, just connect your printer via your usb cord. Your computer will recognize the printer once the cord is connected and you will see a pop up message around the right hand corner of the monitor screen that says "new equipment detected" and the computer will do the rest.
Nov 11, 2010 | HP DeskJet 5650 InkJet Printer
My wireless will not connect to my macbook
First two are mentioned here,
1. wireless
2. usb
if you are using a USB cable to connect, first you have ensure that is system is working perfectly and turned on, secondly make sure u have the printer turned on after proper connection with your usb to your computer from the printer, this is suppose to pop up a message demanding for printer driver installation.
If it does not respond, you have to check your USB port on your system or the USB cable. check these i believe one will certainly work for you. thanks gud luck.
Oct 07, 2009 | HP J4680 Office Jet All-In-One Printer
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
Internet connection problems
Just take out the printer usb cable and put the router usb cale into the usb port and try it . if rob comes again please inform to fixya.com
May 12, 2008 | Compaq Presario 5000 PC Desktop
MFC-8669DN FAILURE
Did you check after installing the printer that you have the printer in 'installed printers' in 'control panel'?
Your printer may have been there, but not set as default printer.
Did you also notice a message popping up first time you connected the printer to usb saying new hardware detected?
Try to install and connect the printer on a different computer ( a laptop will be fine), intalling software first as usual.
If it works is either usb channels on original computer or a windows problem.
If Windows does not see the device when you connect usb (ensure cable is ok) to different computer, and you are sure you are doing everything ok, then it is probably usb printer socket that is faulty.
If Windows see that there is a new device detected, but it cannot install printer, even after doing disk setup procedure fine, then there is an issue either with the printer or with the drivers you are using (they may be for a different operative system for example).
An hardware problem of this kind is rather unfrequent, particularly on a new printer. Check that you are doing everything fine, that the printer is not in installed printer, even if not default one, and that you are using the right setup disk, and that this is performing the whole setup procedure.
Regards
Mar 29, 2008 | Brother MFC-8660DN 5-in-1 Laser...
HP OfficeJet 4315 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
