Question about Dell Latitude D600 Notebook
Does this laptop have the network card slot on the left side?
I have the dell d600 and im trying to find out if the slot on the left side is for a wireless network card?
if you know it would help me out loads thanks!
claire
  • catgoth2007 Dec 09, 2008
    yeah i had to disable the built in one as it wasnt licenced?
    but i dont understand what a type I or II is??
    Scholar:
  • 162 Answers
Check your notebook specification
http://www.itema-pg.com/PC/Notebooks/dell/d600_spec.pdf
About Pci slot type I or type II Type I Cards designed to the original specification (version 1.x) are type I and feature a 16-bit interface. They are 3.3 mm thick. Type-I PC Card devices are typically used for memory devices such as RAM, flash memory, OTP, and SRAM cards.
Type II Type-II PC Card devices feature a 16- or 32-bit interface. They are 5.0/5.5 mm thick. Type-II cards introduced I/O support, allowing devices to attach an array of peripherals or to provide connectors/slots to interfaces for which the host computer had no built-in support. For example, many modem, network and TV cards use this form factor. Due to their thinness, most Type II interface cards feature miniature interface connectors on the card which are used together with a dongle; a short cable that adapts from the card's miniature connector to an external full-size connector.
Posted on Dec 09, 2008
    Sergeant:
  • 236 Answers
According to the specs at CNET
This laptop has built-in wireless, which should be under the bottom cover or keyboard.
The expansion slot on the side is for type I or II cards
Does my laptop (Dell latitude d600) have a memory card slot and where is it?
If you are talking about a slot to Add RAM yes, there is.....there is a little panel on the bottom of the laptop that has a small screw you can remove and add memory.
If you are referring to a memory card READER (like a slot to read compact flash or camera SD cards) no, I don't believe a D600 has one of those.
Mar 10, 2011 | Computers & Internet
I need a wireless card for dell latitude d600
any wireless card in the pcmcia slot or a usb will work. If it came with wireless on the board it may be off check this first before spending money.
Nov 28, 2010 | Dell Latitude D600 Notebook
Where's the SD memory card slot?
The D600 doesn't have a SD Card slot. You'll need something like this:
http://www.amazon.com/SanDisk-Adapter-SDAD-67-A10-Retail-Package/dp/B0002JC2QE
Dec 28, 2009 | Dell Latitude D600 Notebook
Install ethernet card optiplex gx260
That slot is actuall not accessable externaly. The open bay is for the AGP slot right next to it. Directly to the left of that slot you have a riser board the provides 2 additional horzontally mounted pci slots. You'll have to use one of these.
May 11, 2009 | Dell Ethernet Card Network Adapter
Lan connection has disappeared from network but wireless works
Have you run the Dell Diagnostics test? reboot the computer and hit the F12 key, scroll down to the diagnostic option and run the test, it will check hardware and memory etc.
Apr 04, 2009 | Dell Latitude D600 Notebook
Memory slot?
Your computer probably does not have one of those slots if you can't see it on the front of the computer. There are adapters you can buy that will hold the little camera memory cards. They plug into a USB slot. We have one that we use. I also use one that has 4 slots on it for several types of memory.
Jan 21, 2009 | Dell Latitude D600 Notebook
Air card
yes they are called usb network sticks
May 26, 2008 | Dell Latitude D600 Notebook
Inetwork card
Here is the link to the DELL drivers for your unit. I am unaware of what network card you have in your unit and therefore can not point you to the proper driver. However, once you know the network card you have, you can go here and download the appropriate driver for your unit.
D600 Drivers
Nov 22, 2007 | Dell Latitude D600 Notebook
Wireless card not recognized
Make sure you are using the latest driver and software for the card. If you haven't already done so, I would also suggest trying the card in another computer, and a known good card in your D600, to see if the problem stays with your computer or follows the card. If it follows the card to another computer then it is most likely a problem with the card itself. If other known good cards also fail in your D600 it might be something with the D600 card slot. If the slot is the problem then I would recommend contacting Dell tech support. Larry Dell Customer Advocate
Apr 11, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
313 people viewed this question
Alun Cox
