FixYa.com
Tags:
Daewoo DW500M Top Load Washer
Washe machine problem
posted by zai123 on Feb 26, 2007
Hi.. i need help to troublesoot my automatic washer machine. When i push power and start the sound become beet.. and shows e9 error and the washer machine dosn't start..
Comment by zai123, posted on Feb 27, 2007
My Washer machine model is Daewoo DWF-772W. I try to looki in user mannual but doesn't state for e9 and the sound beet continue unless i push powe off button.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 16, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In other Daewoo models E9 error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 26, 2007
Helpful (85)
icansurf
Rank:Wiz Wiz
Rating: 84%, 185 votes
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Solution #3
posted on Jul 25, 2008
Not Rated (0)
akhilravi
Rating: 0%, 0 votes
how do i retify this problem??
please help!!!!!
Can you Help with these Washing Machines problems?
Washing Machines
Kenmore laundry center model...
Kenmore laundry center model... Answer This...
Washing Machines
my water dipenser which is
my water dipenser which is... Answer This...
washing tub it rotate in one...
when we turn the timer the... Answer This...
washing machine door
new machine not used as yet... Answer This...
Daewoo 750
Hi, Our Daewoo won't work when... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
