My problem is that my computer system does not have sound card so no sound certainly.I just gave it to the service center but the card again expired.please tell me how to get my sound system back so that it stays.please tell me which sound card is good for xp pentium dual core. thank you
  • faisal_maqso Dec 09, 2008
    sorry for that i don,t no
Hi I have a sonud card but sound is not coming do u help me
Posted on Dec 09, 2008
Lg plasma tv 50inch older version sound but black screen
Sounds like panel fault. Contact the authorized service center for LG. Gopakumar Gopalan Google
Apr 26, 2014 | LG Televison & Video
How do i solve my problem my system is burning my camera sd card if i insert my card it will shows me card damage it has damage more than 10
It's clear that there's hardware problem with the card slot. Your only solution is to get your computer serviced at Service Centers. You don't need to try again yourself unless it's repaired. The problem could be that there's physical damage inside the system board or in the slot. If you try again, you'll loose another card, so please take it to a Service Center or Call for Service.
Note: This isn't a fixable problem with DIY.
Good Luck.
Thanks for using FixYa.
Jul 30, 2011 | Computers & Internet
My adobe flash plugins are crashing
This seems to me to be your Internet speed may be affecting the flash player it has to have certain DPI's to be able to play a movie or program. You can try downloading it again the flash player at adobe.com or setting the flash player to a lower rating, when I had problems with flash it was my system and not the software program.
Try closing windows that are open as well if any. Clean the machine of any junk and do a defrag on the drive. Less is best also check services that are running and how many programs are also running with the startup. Sound like a computer issue and not the flash player keeping up with the memory of your video card, increase system memory and possibly a new card with more video capabilities. Hope this assisted you. John
Jan 30, 2011 | Adobe Computers & Internet
No audio/sound output from this compaq presario laptop despite having installed realtek audio driver and HD driver? what might be the problem
Well as you mentioned that you have already tried installing the driver then also the issue persists then it might be either a problem with the service responsible for the sound to work or the sound card .
In order to check that the sound card installed on the system is working perfectly we need to perform certain steps.
1.Restart the system and tap on the F10 key for while till we get to the BIOS SET UP UTILITY.
2.As soon as we get to the Set up Utility try tapping on any keys on the keyboard it would give BEEP sound.
3.If we get the Beep sound then the sound card is working and its a problem with the Operating System and we need to perform a couple of more steps,if it does not beep then the sound card is bad and call up Hp to get it replaced or get in touch with a local store.
4.Now if the keys beep on the Bios screen then we need to perform a couple of more steps on the Windows to check the functionality..
5.Click on Start, in start search or run type SERVICES>MSC and then hit enter.
6.Locate a service which reads as WINDOWS AUDIO.
7.Right click on that service and click on properties.
8.Check the status of the service...if the service is already started then the STOP tab would be highlighted or vice-versa.
9.If the service is started stop it and then again restart it, and if the service is stopped start it..
10.Now in the middle of the screen we would see a start up type tab, there would be a drop down menu next to it.
11.The drop down should be set to Automatic
12.Click on APPLY and then OK.
13.Restart the computer and then try installing the Realtek Audio driver and check the functionality..
Hope this works
Regards
KEN
May 10, 2010 | HP Compaq Presario V2000 Notebook
How can i plug in my logi tech speakers on my new dell computer,
  1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Nov 11, 2008 | Logitech Z-560 Computer Speakers
W810i
If you purchased a new phone from the mentioned shop and you're not getting the correct after sale service, which is badly needed by the sound of things. This is what you should do:
Write to or contact:
http://www.sony.co.in/section/contactus?site=hp_en_IN_i
Sony Ericsson won't like the idea that an agent/franchiser gives a bad service.
Jan 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Hey i need help !!
1. Pls ensure that it's body is not broken. Iif yes take it to the hardware service center. 2. If body is ok then Detch the battery and memory card. First reistall memory card then battery. Adjust the right mode for picture. and turn it on and check. 3. If it is ok then connect it to computer by usb.If it is not ok then there is damage to it's circuit board. Go to service centre. 4. If computer does not dectect the camera then also there is problem with circuit board.
Aug 25, 2007 | BenQ DC3410 Digital Camera
Logitech x-530 5.1
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting. Go here to get an operations manual for this setup. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=d*11Q7xi&p_accessibility=0&p_tbl=9&p_id=2924&p_created=1126107772&p_olh=0 Good Luck
Mar 22, 2007 | Logitech X-530 Computer Speakers
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
