Question about IBM ThinkPad T40 2373 Notebook
IBM T40 Laptop screen goes black, will not come back
System starts to boot, get windows logo, may even make it to desktop icons, enables wireless then, whamo! black screen. ntl/alt/delete MAY bring it back for 2 mins, then black again. keyboard seems fine, caps lock works fine on/off. trued func/F7, does not switch from prez output to LCD, suspect my LCD monitor is failing or cables have become loose.
  • 1 more comment
  • The SeaWard Dec 24, 2008
    My T40 too... seems only to happen when the laptop is jostled or if I plug in a USB device sometimes. Screen goes black and am pretty sure the backlight is off. The laptop is otherwise working, so I shut it down and reboot and the screen comes back.
  • gt_stud02 Feb 15, 2009
    The same thing happened to my T40, it got progressively worse by the way. Getting it looked at now is the best way to do it, I found tapping or full out hitting the space to the right of the  mouse helpful, but I think I may have done permanent damage that way.
  • chasega May 11, 2010
    unifi9230 Is this an easy in and out (of the case and motherboard) change of a board? No fine pitch solder or anything? Is this the same part you used? http://www.pchub.com/uph/laptop/43-28080... Thanks, Glenn nhpcfix at yahoo
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Posted on Mar 08, 2009
I just replaced the inverter card on my T-40. This solved the problem of the screen going black after a sortly after booting.
Posted on Feb 18, 2009
  • IBM Master
  • 4,806 Answers
Sounds like the display is set to turn off after a minute, go into display properties and set the display not to turn off at all
kind regards and please don't forget to rate us
Posted on Dec 09, 2008
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
How do i turn the wifi on on my lenovo ideacentre b3?
Step 1:
Feb 24, 2013 | Computers & Internet
Black screen right after dell logo
start tapping f8 after you boot the machine, when given the boot menu, try to load safe mode, and see if it loads. if it does, then you need to do a system restore back to before you got the black screen. more than likely windows loaded an updated driver that disagrees with your system. try that and let me know what happens :)
May 25, 2012 | Dell Studio One 19 PC Desktop
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
My ibm laptop, was working great until this morning, the screen started to flicker, then the icons started to dim and completely disappear and then the screen went to a coloured test pattern and finally...
Check the power supply.Hope the notebook receives power from the battery or the Ac adapter.We need to ensure there is no issue with the power supply.boot the notebook to the safe mode.If it boots to the safemode perform a system restore.In case the notebook does not boot to the BIOS,connect to an external monitor.If we still do not get a display,its the video card
Mar 02, 2010 | IBM ThinkPad T40 2373 Notebook
I have an IBM T40 Laptop and I wanted to display my video to the television screen via the SV output. When I hook everything up, all I see on the television is the Windows Desktop background, no icons etc....
You set it to Multiple Monitors (if you move the mouse, you will probably be able to see it on the TV once it "goes out" of the laptop desktop). You need to change output mode to external S-Video.
First of all try hitting Fn + F7 key to switch to Ext-S-Video. If it works, that's it, of course. If it doesn't, TV output is not enabled.
Right-click on the desktop to bring up the Properties, go to Settings. You'll see two monitor images there, 1 and 2.
Click Advanced, then go to Displays. You'll get CRT, TV and LCD. Turn on the TV button and tune your settings.
At this point, the hotkey Fn + F7 is enabled to cycle between LCD and TV.
If it still doesn't work and you see the blank desktop, go again in Display Properties, choose LCD as Primary Display, select Secondary, and verify that "Extend desktop on this display" is NOT checked.
Nov 03, 2009 | IBM ThinkPad T40 2373 Notebook
Thinkpad 42 on startup screen is in a red pigment then goes to the blue welcome screen then goes completely black. On occasion may see my desktop for a moment.
This sounds like a display card (graphics card ) driver issue, or else the screen is going bad..
test that out by hooking up an external screen to the port on your laptop.. Then toggle using your function keys to use the external display..
If the external display allows you to see your desktop..
reload your graphics card driver, then boot up normally..
if the screen still doesnt work, you may need to replace it
Oct 30, 2009 | IBM ThinkPad T40 2373 Notebook
Laptop boots up for 2 seconds and then goes to a black screen
just remove your ram if u can and wipe it with the clean cloth and insert it again so that the bios mite reset... or you have to change the jumper on the mother board which you have to take to an technician and get it done...
Jul 30, 2009 | IBM (92P6581) for ThinkPad T40 (92P6581)...
Ibm t40
Yap actually i greet you first
what your system is prompting you is that your Processor is getting Bad and you will need to replace it with a new ones ok
After that your system come back to life .
thanks
Rate this solution
Oct 20, 2008 | IBM ThinkPad T40 2373 Notebook
Ibm thinkpad t40
http://en.wikipedia.org/wiki/Blue_Screen_of_Death
http://support.microsoft.com/kb/174630
THe most popular windows issue in all the land.
Oct 24, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
3,050 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
