I wanna set up CAS (computer algebra system) on this calculator. is that possible? how can i do it? thanks :)
I am sorry to say, but there is nothing for you to set up. Anu calculator comes with a CAS or does not come with a CAS, and this one does not.
If you want a calculator with a CAS, here is a list of some of them
Casio FX-Algebra 2.0
Casio ClassPad 300/300 Plus/330/330 Plus
HP 50G/49G+/40G39G+
Texas Instruments TINspire CAS
TI Nspire CX CAS
TI Voyage 200PLT
TI 89 Titanium
TI 92 Plus
SOURCE: My Casio Algebra FX 2.0 calculator won't
I suggest you reset the calculator by removing the main batteries. This will free up space to solve the problem.
Hope it helps.
SOURCE: Is it possible to get euler's number on this
There is no key dedicated to e, the base of natural logarithm, the same as there is for pi. However you can find it as the VALUE of the exponential function e^(x) for x=1. To obtain the VALUE of e you press [SHIFT] [ln] to access e^x, enter 1 and press [EXE].
Thus
[SHIFT][LN]1 [EXE] gives 2.718281828.
If you need that numerical VALUE often you may want to store it into a variable, say E. To do that
[SHIFT][LN]1 [-->] [APLHA] E [EXE]
From experience, I know that it is not the VALUE of e that you need but the symbol e to define the exponential function. If you press [SHIFT][LN] you get a syntax error. You can never see e in a multiplication, addition, or other arithmetic operation.
In this calculator, the e is first and foremost the symbol for the exponential function. If you need to draw the exponential function of X
you press [SHIFT][LN] X. Parentheses are not needed for simple arguments as this one, but if the exponent is a complicated expression parentheses are needed.
If you mean exponential of X you type [SHIFT][LN] [X,theta,T], but if you want exponential of (x-3z+ 0.5 y^2), you must enclose the argument (the object of the function) between parentheses
[SHIFT][LN] [ ( ] x-3*z+ 0.5*y [^]2 [ ) ] [EXE].
Hope it helps.
SOURCE: I want to calculate eigenvalue by Algebra fx 2.how
Only FX 2 Plus can calculate Eigenvalue and Eigenvector
On main menu num 9 (CAS)
OPTN-MAT-CALC-EigVl or EigVc
