Question about Astatic 636L Noise Canceling Microphone Microphone
Mic problem 4 prong astatic636-l need wir number- combination what color goes with what number
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, the 4 pin mic connector and corresponding pin # would depend on the communications equipment the Astatic was initially wired for. However, the color coding of the wires in an Astatic would be:
  • white - mic audio;
  • shield/blue - gnd;
  • black - NC or speaker;
  • red - NO or PTT;
  • yellow - not normally used.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 09, 2008
Need to know what color wire goes to what prong haier mini-refrigerator thermostat
Fridge stats use a standard numbering system in the pins, all you need to do is swap them like for like from the old stat, i.e 3 > 3, 4 > 4, 6 > 6.
Sep 22, 2014 | Dryers
Tring to wire up sadelta hand mic the mb-4 to the superstar 3900 but dont know the wiring there are 5 wires the couler of the wires are screen white red green andbrown can you help
I would like to state there are two ways to do this, one way is too open the radio cover up and look at the back of the jack where the mic goes and the color of the wires should be the same, or you can do it the second way which is a little longer and patience to do take the wires of the mic and touch one at a time to a prong one should get you sound when its right the other should transmit when you push the handle to talk on the mic
Jun 02, 2014 | Superstar 3900
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
I am trying to change my miller welder 4 prong plug to qa 3 prong to match my dryer outlet ? which wire goes where ?
On 4 wire outlets the neutral and ground wire were seperate on 3 wire the ground and neutral are combined so hook up the 2 hots (black&red) as before on the 2 outside terminals and combine the green and white together onto the center terminal
Nov 12, 2011 | Whirlpool LER5636P Electric Dryer
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
Hi i need to know the color code to assemble a new 3 prong stereo 1/4 inch jack for a shure sm 58 microphone. i need to know the order and color to reassemble the mic cable to a new 1/4 inch guitar type...
Unfortunately, different cables use different colors of wires. Thus, you'll have to see what colors are connect to both ends of the cables. Here is the wiring:
XLR -> 1/4 inch
Pin 1 -> Sleeve
Pin 2 -> Tip
Pin 3 -> Sleeve
Dec 24, 2009 | Audio Players & Recorders
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Road king 56 4 pin mic
take a wire or small screw driver across any two pins you are looking for a earth from tx to tx the last pin is mic. on mic side use a multimeter earth is braid, find rx lead next . key mic multimeter shows 0 tx. audio has a higher value .
Apr 08, 2009 | Magnum DeltaForce CB Radio
Mic wiring prob.
From the Astatic wiring guide, here is the information for the DELTA FORCE
WH-1
BK-2
RED-3
SH & BL-5
Rollin CBs
Dean
Dec 09, 2008 | Magnum DeltaForce CB Radio
Astatic 636L Noise Canceling Microphone Microphone Logo
235 people viewed this question
Top Astatic Audio Players & Recorders Experts
Michial Gueffroy
Tony
 steve
steve
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
