Question about ViewSonic N2230w 22 in. LCD TV
No sound we used it as a tv so i know the speakers work but now that i am using it as a monitor, there is no sound
    Genius:
  • 1,550 Answers
Look for a cold solder joint in the vertical drive
Check the inductors in the vertical drive for a cold solder joint where windings attach to pins, as well as any transistors in the vertical drive section.
Check the caps in the power supply providing the low voltage to the audio and video processing IC's
Also chance that you have a bad X sustain board
Posted on Dec 09, 2008
    President:
  • 1,450 Answers
You will not get sound using it as a computer monitor unless you run rca cables to it. I am running a 27" viewsonic and it soesnt have sound now either
  • TripleTauto
    TripleTauto Dec 09, 2008
    further research is showing that when in vga mode the speakers are not functional bsically it turns into a monitor without speakers
I have a Dell W3706MH tv monitor and the sound just stop working. I unplugged the speakers and plugged them back in still no sound. I unplugged them because it was making a loud buzzing and popping noise...
If possible, plug the speakers into a portable device such as a cell phone, portable cd player or a tv that is equipped with a headphone jack (if speakers have the jack). If not, if the speakers have the red and white, ref and black or black and white male end connectors, plug them into a tv or dvd\blue ray player. If you get sound they are good, and you need to adjust your sound options on your computer. Let me know if this helps\works. Also, not all speakers are compatible with all computers and must have the same sound level equivalence to the device they are being used with. i.e. Ohms etc.
Aug 29, 2014 | Televison & Video
Xbox360 to pc monitor
HDMI to DVI works better than HDMI to VGA because VGA only uses simple RBG scheme.
Additionally the only way i see the Xbox getting connected to the extrenal speakers is if you get the speakers connected to the monitor/tv or whatever you are using directly. I havent tried or do not know of any way to connect the Xbox to speakers directly.
Dec 17, 2013 | Microsoft Xbox 360 Console
Monitor works perfectly, but after a recent crash of my comp. Ive lost all sound ..The comp doesnt seem to recognize the build in speakers..
The computer does not have to recognize the powered speakers that are built-in the monitor, the computer feeds the analog audio signal the powered speakers inside the montior, there is no driver needed either, but you do need the PC sound card driver for you to get sound through any powered speakers (either the desk top powered speakers or the one inside the montior).
Since your computer had crashed, the driver for the sound card may be have to be reloaded.
You can verify if the monitor speakers are working or not by feeding it with an MP3 player or sound output from CD player.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 14, 2011 | BenQ FP72E 17" LCD Monitor
I don't have the sound disk anymore and the monitor is not producing any sound. When I try to download the driver my computer says it doesn't recognize my model VA1930wm
The monitor driver is for your computer to recognize all the resolutions your monitor can handle, there is no sound driver for the monitor to work since the monitor built-in powered speakers are jsut that, powered speakers, same as the one you buy if the monitor does not have built-in powered speaker.
You can test the monitor speaker system by feeding it with the MP3 player or any sound sources.
It may have bad power amplifiers IC. You will be better off spending money on a good set of PC powered speaker system that will provide a lot better sound quality than the quarter-size speakers in the monitor.
Apr 21, 2011 | ViewSonic VA1930WM LCD Monitor
I have a samaung pc/tv monitor,i use for pc and tv use,i have external speakers for the pc and would like to connect them also for the tv as the sound as is not very good,putting the tv menu in external...
Some actual model numbers would make this conversation more relevant.
If your PC speakers are self-powered they should accept the RCA output from any device that provides headphone or Line Level audio.
Where is the TV audio actually coming FROM? Maybe a Cable Box? THAT is where the PC speaker should tap in.
Many TV's have a Fixed or variable audio output. Fixed allows for disabing the TV speakers or turning its volume down without affecting the audio out to other devices.
Mar 13, 2011 | Audio Players & Recorders
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Bypass hdmi to get sound to PC speakers
does your tv not have an audio out, if so, you could turn the tv's internal speakers off and just use the audio out jacks instead.
Feb 26, 2009 | Westinghouse 25.5" Widescreen Flat Panel...
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Pc hook-up/sound issues
on the bottom of the monitor there is a audio input. you must connect you pc output(green) to the monitor input with a male to male audio cord. you can also use a rca cord with two adapters.
Oct 24, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
ViewSonic N2230w 22 in. LCD TV Logo
35 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
