Question about Seagate Barracuda 7200.7 160GB 7200rpm 100MBps Ultra ATA/100 (ATA-6) Internal (ST3160021AFT) Hard Drive
No external hardrive recognition
I have installed a new external hardrive a seagate 7200.9 160gb in a welland sunbright enclosure. Am running windows XP. After plugging in drive with USB2 connection "found new hardware" comes up, followed by "new hardware is installed and ready to use" but no icon comes up in my computer as if it is not there. After checking device manager it shows up as there and working correctly but still is not accessable through any program or My computer. Have unistalled through device manager and reastalled a number of times, have restarted computer, have changed cables and plugs, still nothing. Computer came with a multi card reader that registers as 4 seperate mass storage devices, have suspicion that there are too many to recognise but don't want to uninstal any unesseccarily as I don't have the drivers to reinstall afterwards if it does'nt work. Any suggestions would be great as it is very frustrating that everything says its working properly but it does not show up and is therefore unusable. Thanks Wayne
    Novelist:
    Scholar:
  • 104 Answers
It could be that the drive is not formatted/Initialized as yet! Right click on "My Computer" the click on "Manage". Go to(click on) "Disk Management". If the initialize disk wizard comes up automatically then just follow the wizard cause that means your disk needs to be initialized. On the right pane you should see all the disks and their status. It could be that your disk is un allocated. Look for the disk that is full black(black means unallocated), right click on the disk and click on "Create Partition" Follow the steps of the Create Partition Wizard( It will give you the option to format, DO THAT! If when you right on the disk and all that shows is "Initialize", then do that! and go back and create the partition! Hopefully that should do the trick!
Posted on Mar 18, 2007
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
Hello, I just bought a Seagate Free Agent Go 1
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 20, 2010 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
My hardrive is plugged into my mac, the light is on, the hardrive is spinning, but no icon shows up on my desktop. I've searched my computer, and the icon isn't anywhere. I don't know how to access it...
* the USB cable
* the power-adapter
Nov 18, 2010 | FireLite (USBFLB80) Hard Drive
My hardrive "simpledrive" model 96300-41001-156
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
My mac wont read my external
Connect it to another computer, to see if the Seagate device works at all.
If not, then disassemble the enclosure, remove the disk-drive, purchase a new, compatible, disk-drive, and install it into the enclosure, to "revive" your external storage device.
Is the manufacturer's warranty still valid? If so, exercise the warranty, to get a replacement, at minimal cost to you.
Nov 02, 2010 | Seagate FreeAgent Pro 500GB External USB...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500gb external hardrive cannot run after installed
yes , depending on which system you are using . this can be very easy. click on hard drive but dont open it right click go down to format and format it to ntfs . slow or quick format if nothing on.
Jun 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer won't recognize my HDD in my external enclosure...
Hi, Initially, allow Windows to install automatically drivers or needed configuration, then perhaps you need to reboot. Thereafter check if it can be seen in My Computer, otherwise, pls post back for any messages or errors. Good luck and kind regards.
Sep 03, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
3.5" Dynex USB 2.0 External Enclosure + Seagate Barracuda 7200 RPM 500 GB HDD problem with computer recognizing the HDD and the enclosure
 If your running XP , go to control panal , Admin tools>Computer Management >Storage > Disk Management . Look for it there . If its there see if it says what file system . If none format it . If it isnt there then chack the jumper on the hard drive it self . It should be set to master or cable select .
Sep 03, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
279 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
