Dell OptiPlex GX260 Intel Desktop PC - Intel Pentium 4 2GHz, 256MB DDR, 40GB HDD, CD-ROM, Windows XP  Logo
Anonymous Posted on Jul 09, 2012
Remove monitoringprogram called themida from memory
When i try 2 download aprogram or game from give-a-way of the day mycomputers says amonitor program has been found running in my system please upload it from memory and restart your program
  • Anonymous Jul 11, 2012
    problem solved by member named brian his solution was riteon thanks 2 all fix-ya family
Brian Sullivan
Level 3:
  • Dell Master 27,725 Answers
  • Posted on Jul 09, 2012
Brian Sullivan
Dell Master
Level 3:
Answers
27725
Questions
Helped
5664168
Points
79191
Scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running if you see anything you dont need running select end now you might uninstall this specific program if you dont need it your computer does not need it
also under processes see what is ticking over again if you see something you dont need to be and users you will see who is using your computer
hope this helps
    big thank-u 2 brian sullivan
  • Brian Sullivan
    Brian Sullivan Jul 12, 2012
    well done and hope all is good for you now
Themida
what are you trying to remove? have a look in the phone book for removalist in your area
How to download a games to a psp version 6.10
How to Download Games onto PSP- Step 1-
Your regular PSP games will come on disc, or UMD as they are known. When you download games onto PSP however, you are going to be putting them straight onto a memory stick/card. (Some people call them memory sticks, and some people say memory cards, but they are in fact the same thing.) The standard PSP memory card of 32mb is just not going to be big enough to download games onto, PSP owners should generally get the largest one they can afford. These days you can find fairly affordable 2 or 4 gig models on Ebay and Amazon quite easily. Once you have your new memory card, you will need to format it before use. This is basically like wiping the slate clean before use, so be sure to do it.
How to Download Games onto PSP-Step 2-
You will need to locate somewhere to download the games from. There are hundreds of places online that will allow you to download games onto PSP, but unfortunately they are not all reliable-if you go to the wrong places you will encounter many problems and can even find your computer riddled with spyware after. Not good! Be sure to choose a reputable site to download PSP games from-the most reliable ones are the ones that charge a small fee upfront and then give you access to unlimited downloads.
How to Download Games onto PSP-Step-3-
Once you begin downloading to your computer, be sure to only download files that end in "PSP" or have "PSP" in the title, as they are the only files compatible. You will occasionally find that the untrustworthy sites out there will try and give all kinds of files as downloads, so be sure to double check everything before you download it. When downloading the games I save them to a little folder on my desktop called "PSP Downloads, as it's simply the easiest place!
How to Download Games onto PSP-Step 4-
Now that you have a selection of games downloaded, you will need to transfer them from your PC onto the memory card of your PSP. This is pretty simple, all you will need is an ordinary USB cable to connect the two, and the PC should then identify the PSP as some form of removable drive, like a flashdrive or removable HD. All you need to do from here is to open up the PSP using the PC and drag and drop the required files onto the PSP memory stick, much as you would with any other removable drive. When you are doing this, be sure to send the files into folders called PSP, and then GAME on your memory card. If they don't exist you will need to create them, and I would recommend using all caps.
How to Download Games onto PSP-Step 6-
Once the transfer is finished you should be able to play the games on the PSP by simply opening up the GAME menu and selecting the games from the stick. Any errors or error messages are likely to be due to incompatible firmware-this is especially true if downloading homebrew games. You may find it necessary to downgrade your PSP in order to play these homebrew games.
Hopefully this guide has helped you see that it's not that tough at all to download games onto PSP once you get the hang of it, the real trick is finding a reliable download source!
I would suggest downloading PSP games using torrents. Just go to www.thepiratebay.org and search for PSP games. You'll need to have mutorrent or some other torrent software on your computer to download the torrents with. Follow the instructions once you have the downloaded game via a torrent and you'll be good to go. Good luck.
8helpful
3answers
I am using SAMSUNG GT S3600i mobile phone. I have many queries like (1) How can i format my phone memory? (2) Can i upgrade my phone using pc studio? (3) How can i download files in my memory card using...
(1) Try to do a Samsung Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in). (2)Yes, you can. (3) Just download it
2helpful
3answers
How can we download psp games now
these are the steps you will use to download a game on your psp.
step 1
step 2
step 3
step 4
step 5
Please rate my solution.
Thanks
How 2 download psp games?
  • Download desired game from an Internet game site onto your computer.
  • Connect the PSP to the computer using the USB cable. The memory stick needs to be in the console at the time of connection.
  • Copy the downloaded game files into the PSP game path on the removable drive. This puts the downloaded game onto the PSP memory stick.
  • Disconnect the PSP from the computer once the game has been fully transferred.
  • Look in the PSP main menu from the game folder. Scroll to "Game" and select the memory stick option. Press the "X" button to display the list of available games.
  • Select the downloaded game and begin playing.
Good Luck and have a nice day.
I want free downloads of sony psp3000 memory stick games
For you to download and play games on your psp, please follow the steps listed herein;
1. Since you can download directly to your PSP memory stick, you'll have to download to your computer and further transfer to your PSP memory stick.
2. You'll have to modify the PSP from the official version to a custom version. You can find out how to do this by typing in this search "How to hack PSP to custom firmware"
You can now do the following to transfer and play games;
a. Get a good memory stick. I recommend that you get a Memory Stick Duo in at least a 1 GB size, though a 2 GB is even better.
b. Find and download the PSP games you want. If you don't know where to find the games try a download service. A good one will let you have unlimited downloads for a small one-time fee. You can see the link below for more information.
c. Unzip the game files and save them somewhere that you can find them easily, like your desktop.
d. Plug your PSP USB cable into your PSP and your computer.
e. For PSP games- go the the root directory on your PSP then make a folder called ISO. (If you downloaded PSOne games, go to the root directory on your PSP and find the folder called PSP/GAME.)
f. Copy the PSP game files into the ISO folder. (Copy PSOne game files into the PSP/GAME folder.)
Once this is done you can now play games on your PSP.
Regards
Computer shutting down ( hard shut down) with out notice
This sounds like you may have some bad RAM, or your processor is overheating.
Try running Microsoft Memory Diagnostics:
http://oca.microsoft.com/en/windiag.asp
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3helpful
2answers
The error message i get when playing atlantis ii is "the instruction at 0x00d36f70 referenced memory at 0x00000000 the memory couldn't be written"
though i need to know abt the os platform n the system configuration..
itz probably a case of software corruption or memory refresh n allocation..this can also b a symptom of faulty/defective of RAM..open clean/removecarbon & or oxide formed on the teeth with an eraser n resitit..[it'll b more prominent, that if itz cause by ram or not,..if duringnormal operation, a Blue Screen appears/Memory Dump]
(though, sometimes itz also caused by the m/b)..
uninstall n reinstall it again..
try increasing or replacing the ram..
howevr, hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find whatto remove,post me/us in ur comment with all the items listed in eachn every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disablethe following: a) 'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart; b)'Error Reporting' right click on mycomputer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
for professional supervision, contact ur system admin/vendor....
I bought the game Zuma Deluxe months ago and something happened to the memory on computer. I had new memory put in and loaded the game yesterday and now it says that I have to buy game again. Why
welcome to fixya
the memory of the computer held the code for the game...when the memory went the game files was messed up ...
and now the game thinks your trying to us the game in a different computer
call the maker of the game might give you a new code to use
i hope this helps out have a good day :)
Im my PSP Some games will play others won't what give?
Need to upgrade the firmware...sony needs firmware updates to play new games, add features...and attempt to slow piracy. Ro up grade your system go to settings and network update...if you do not have a wireless network to connect to you can download the updates and put on a memory stick from sony.com
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
