I cannot ajust the colnvergence blue is ok can"t ajust the red
  • 4,234 Answers
Depending upon the set, the probable issue is either poor connections on the pins of the convergence IC or a defective IC. If you can update this with the make and model, I can confirm this and provide additional details and instructions.
Dan
Posted on Dec 09, 2008
Blue shades on left side of the screen
Hello seems like u have a convergence problem if the colour red /blue /green around the outside of people or objects in one of these colours the convergance chip will need replacing but u can also check in your menu to see if this can b ajusted by remote only sometimes .
Apr 11, 2010 | Toshiba 43A10 43" Rear Projection...
My convergence won't fix the color problem. When trying to use the convergence ajustments on the tv, the red is ok but the blue won't realign. The blue is bowed from the bottom about 8 inches and slightly...
Check all the resistors that are connected to the stks especially the 3 that have same values, resolder if required. Also use a magnifing glass to check on embedded resistors on the soldering side of pcb. you may have unknowing desoldered one of them or caused shorting. These will be small ant size blackish rectangular resistors. most DIY people mess them up. Some tvs may have them too close to the stk terminals and require careful desoldering and soldering while replacing the stks. vote if it helps and thanks if you voted. check out www.fixurtvs.com
Apr 09, 2010 | Panasonic PT-53WX53 53" Rear Projection...
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
We have a gas whirlpol that was converted to
on the gas valve there is a orfice a pin hole you can ajust the size of the orfice by tighting the ajustment a little a 1/4 turn . it is on the valve where the gas gos out to the bunner usualy a 1/2 in open wrench fits on it its made of brass you have to open the top to see it there is also a air ajustment where the bunner fits over the gas valve orfice if the flame is red open it more if its to hot close the air a little make the flame red then turn the gas down tell its blue agin
Oct 20, 2009 | Whirlpool Ovens
Color not right
HI
you have defective RGB Circuit The Red, Green, Blue, You have shorted Green Circuit in Crt circuit this needs to diagnose to locate the shorted parts...
Thanks!
Apr 12, 2009 | Zenith B27A11Z 27" TV
Works but prdominantly green, can't ajust with color controls
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
Mar 07, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Sony kp-61v45 Blue Convergence off by 2 inches
you need to replace the convergence board its around 80 dollars
Aug 17, 2008 | Sony KP-61V45 61" Rear Projection...
I cannot ajust my screen the colours are awful
Check your vga driver is working ok otherwise run the vga driver setup ajust the resolution and refresh rate your monitor will be ok
If you monitor is red/blue or yellowish then you have to replace it because colour
Go to control panel then choose system - hardware - device manager - > expand the display adapter any exclamation mark or question mark there.
That means you have to reinstall its driver .
Thanks Hothawk
Jul 25, 2008 | Computers & Internet
Red and blue light ajust but green one will not
believe you would have a open resistor on the green crt board, was either a 120k or 110k resistor
Oct 28, 2007 | Zenith IQB50M90W 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
