Question about Jenn-Air JJW8630C Expressions Collection Electric Double Oven
Top oven has an error code (f2) It happen after a cleaning
The fan stays on the oven will not heat up until it is set on 400 or greater
  • 28 Answers
F2 - Oven Temperature Too Hot - Depending upon model, replace relay (if present) or oven temperature sensor. Make sure to check sensor harness.
Posted on Dec 09, 2008
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
After cleaning oven the fan will not go off and a F2 or F3 flashes.Turned power off and fan starts up as soon as power is restored. I think I pressed wrong timer when I set the oven to clean. I had to get...
It will help to know what f2 & f3 stand for. These are fault codes and there usually is a tech sheet taped to the back of the oven, or inside the control compartment of the oven. If you open thecontrol area, you can look at the sheet and know what failed by the list of fault codes. Unfortunetly, it could be the control board again (these are very fickle electronics), or it could be the oven lock mechanism,or the overheat sensor that keeps telling the fan and other components to stay in their operating mode. it is like the domino effect: one item goes flukey and the rest fall prey to the results. Good luck, Macgivor
Dec 27, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
F2 error and door locked display while self cleaning and fan will not turn off for 4 hours after using oven
F2 during the cleaning cycle will occur when the oven control senses an oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
**((The fans will continue to run if the control has been damaged, due to the high heat))
Sep 09, 2009 | GE Profile JTP56 Electric Double Oven
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Jenn-Air JJW8630C Expressions Collection Electric Double Oven Logo
144 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
