Question about Microsoft Excel for PC
Excel lookup - match index array
Any ideas & help appreciated
Excel spreadsheet with around 100,000+ names, titles, numbers, Title & Notes across multiple sheets
I need to a formula search the Title & Notes section - which is a single cell entry against a series of defined lists to separate out things like Title, Seniority, Products etc These lists are in named ranges and the information to be searched is in this single cell per entry. I need to be able return multiple exact matches from each of the search lists.
eg. Title & Info contains information like this:
MD1 '06 - FI Sales - UK IMG's - Ex Barclays 26/1/04 - BB1008
I have defined a list series of selectors for Seniority: shortened below
Analyst
Associate
Director
MD
so in the above example I only want to return "MD" as an exact match from the list under the column for Seniority. I appreciate that this will not be perfect as the search will also pick up those letters in regular words but this is miniscule in comparison to database size.
Under JobFunction - I want to return "Sales" as a match from the selector list of JobFunctions
For information with regards to Client Type & Client Location the formula has to first pick up a "sales" entry. So will need an IF statement.
Client type will be "IMG's" matched from the ClientType list.....
The results should look something like this
Seniority JobFunction Products Client Type Client Location
MD Sales FI IMG's UK
There are people that will have multiple entries for
This is being done to "pre-skill" people prior to input into a relational database.
In effect the formula is like this
MATCH(JobFunction,within cell G2,return matched item(s))
if "Sales" is present then search to add client type and/or location
Clear as mud!!
Regards
Chris
  • onealchris May 11, 2010
    Did you get a solution, yet? (I just found this site, but I like it!) If not, could you send me a partial copy of the file?
  • JULIAN May 11, 2010
    Since you seem to be familiar with Excel functions, I suggest downloading a utility named ASAP and see if any of those extended functions can help you. In the mean time, I will study the problem and see if I understand what you are trying to do. If possible, could you send me a partial copy of your spreadsheet? 10 or 20 rows should be sufficient. (I'm not sure what procedures are available in this site to submit files, so, unless it's ilegal, I will give you my e-mail address if you request it)
    President:
  • 1,187 Answers
The best solution may be to re-define the named columns, or to add new names to multi-column arrays, then use the VLOOKUP function.
Note that the "indexed" named cells must be sorted by the index column.
Test (this is a 2 year old question)... Please ignore ths following. The plus symbol does not display.
Upper key plus symbol displays:
Right plus symbol on number pad displays:
[Shift] Right plus symbol on number pad displays:
[Alt] [4] [3] displays:
slash/slash/plus displays: //
slash/plus/slash displays: / /
Plus Plus Plus displays:
upper Plus Plus Plus displays:
Shift Right plus plus plus displays:
end of plus test.. thanks.
Posted on Oct 06, 2010
Sum numbers in a column down until you come to a blank, then start again
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Sep 03, 2014 | Microsoft Excel for PC
What is excel
Microsoft Excel is a commercial spreadsheet application . It features calculation, graphing tools, pivot tables, and a macro programming language called Visual Basic for Applications.
Microsoft Excel has the basic features of all spreadsheets, using a grid of cells arranged in numbered rows and letter-named columns to organize data manipulations like arithmetic operations. It has a battery of supplied functions to answer statistical, engineering and financial needs. In addition, it can display data as line graphs, histograms and charts, and with a very limited three-dimensional graphical display.
Regards,
Shrey
Jun 04, 2011 | Microsoft Excel for PC
If I have a multi-row s/s that has multiple pages, how do I get the row title for columns to appear on each page?
Hi, I believe you're asking about 'freezing panes'...
In Microsoft Excel 2007:
  1. Select the place on the spreadsheet where you want the row titles to appear
  2. Click on the View tab
  3. Click on Freeze Panes button
  4. Select Freeze Panes
Or, you could be asking about defining print rows to appear at the top of each page:
  1. Select the Page Layout tab
  2. Click Print Titles
  3. Enter the Rows to Repeat at Top (e.g., 1:3 for the first 3 rows)
Hope that helps!
Feb 01, 2011 | Microsoft Excel for PC
HLOOKUP IN MS EXCEL
lookup value = value searched
table array = database
topmost row of lookup array must contain the data IDs and all IDs must be sorted in ascending order.
row index number = row number containing data to be shown; first row = 1
hlookup(x,tablearray,y) will look for x on the first row of the lookup table and return the value in the cell on the yth row
if formula cannot file exact x, it will look for the value closest to. but not greater than x
Nov 13, 2008 | Computers & Internet
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Excel problem
Is the stock register an excel spreadsheet?
May 10, 2008 | Computers & Internet
Vloop
Are you referring to the VLOOKUP function in Microsoft Excel?
I love vlookup!
Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B:
Song# Title
123 Love Me Tender
234 Blue Suede Shoes
345 Dixie
Another worksheet has song number and performer in Row 1, Cols A:B
Song# Performer
123 Elvis Presley
234 Carl Perkins
456 Cher
Notice there is NO performer for song number 345 in the 2nd worksheet.
Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B)
Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet.
Help me out Mr. VLOOKUP.
Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0)
Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A.
That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet.
That is why I prefer VLOOKUP over LOOKUP.
I have found this explaination of the VLOOKUP parameters helpful:
1. Needle (A2)
2. Haystack (Sheet2!A:B)
3. RELATIVE Col containing result (2)
4. Need DIRECT MATCH ONLY (0)
Hope this helps.
Jan 07, 2008 | Computers & Internet
M.S. Excel , vlookup formulla tell me use
I love vlookup!
Song# Title
123 Love Me Tender
345 Dixie
Song# Performer
123 Elvis Presley
234 Carl Perkins
456 Cher
1. Needle (A2)
Hope this helps.
Oct 10, 2007 | Microsoft Office Standard for PC
About function
I love vlookup! Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B: Song# Title 123 Love Me Tender 234 Blue Suede Shoes 345 Dixie Another worksheet has song number and performer in Row 1, Cols A:B Song# Performer 123 Elvis Presley 234 Carl Perkins 456 Cher Notice there is NO performer for song number 345 in the 2nd worksheet. Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B) Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet. Help me out Mr. VLOOKUP. Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0) Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A. That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet. That is why I prefer VLOOKUP over LOOKUP. I have found this explaination of the VLOOKUP parameters helpful: 1. Needle (A2) 2. Haystack (Sheet2!A:B) 3. RELATIVE Col containing result (2) 4. Need DIRECT MATCH ONLY (0) Hope this helps. Let me know if you have any questions.
Aug 27, 2007 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
508 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
