Question about Brother MFC 420CN All-In-One InkJet Printer
Brothers mfc-240c printer doesnt print color from paint shop pro
I just bought a Brothers mfc-240c printer but it will not print color pictures when I sent them from Paint Shop Pro 6.0. It prints color fine from other software like PRint Master. Do I need a new driver or an updated version of Paint Shop Pro? Paint Shop Pro has always worked with my other printers.
SOURCE: MFC 440cn, lost mfl pro suite
The advice given so far is not entirely accurate.
On the Brother Wesbsite:
Select the downloads link.
When searching for your download
Step 1:
make sure you have "ALL" selected
Step 2 and 3 are self explanatory
Hit the search button and then you are looking for the download that says "full software and driver package".
Install as directed.
Posted on Dec 01, 2008
crayzeetrayn
  • 837 Answers
SOURCE: To find user's guide for a Brothers MFC 240C
Here is the link
Give me a FIXYA please .. thanks
Posted on Dec 07, 2008
  • 124 Answers
SOURCE: lost driver from new MFC-290C NEED MFL-Pro Suite
Here's what you need to download:
http://www.brother-usa.com
Upper right side, downloads and support, click Downloads/FAQs/Help and more.
From the drop down in the middle of the page, select:
Multi-Function Center (MFC and DCP series)
Select model MFC-290C, click View Support Information
Then click MFC-290C Downloads on our Online Solution Center
Select Drivers, pick your operating system, then your language, then Search.
Download the Full Driver & Software Package and you should be good to go. :)
Posted on Feb 20, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
KingDWS
  • 1606 Answers
SOURCE: MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Posted on Aug 17, 2009
Can my brothers mfc 240c printer be used to print from more than 1 computer in my house wirelessly? how do I set this up?
The MFC-240C does not have a wireless interface, so you can't connect wirelessly directly to it. What you would have to do is set up a print server, which can be a standalone device or can be one of your computers, and then the other computers would print through that one connected computer.
Jun 26, 2010 | Brother MFC 240C All-In-One InkJet Printer
Can my brothers printer work only on black ink (MFC 465 CN)
I am afraid you cannot print if (any) one of the cartridges is empty. Here is a screen capture from the properties of my MFC. At the bottom of the picture it says in French : Le MFC arrêtera l'impression Couleur/échelle de gris lorsqu'une ou plus des cartouches d'encre sera vide.
What it say in English is as follows: The MFC will stop printing in Color/Gray scale when one or more of the ink cartidges is empty.
Open the properties of the MFC. Under "Advanced" Tab Click the Printing Defaults at the bottom left. At the bottom of the window that pops up you will see the information that I translated for You.
Jun 30, 2010 | Brother MFC295CNAll-In-One InkJet Printer
Need to replace drum kit in a 240c brothers printer
drum unit is part of laser printer and MFC-240C is inkjet printer
parts that you might replace is print head, ink cartridges, ink absorber box
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brothers MFC-240C not printing in color???
Do you have it set to print in black and white as the default? Go into the print driver, under Color Management, and select Color.
May 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Hi.. My Brothers MFC-290C printer is printing in pink. I need it to print black
Have you tried to clean the printer heads? usually there is a software application that will offer the ability to clean print heads, align the printer, shows the estimated ink level. This sounds like only one shade of your color head is coming thru.
Brian
Mar 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Hi I have bought new in black cartridge and nothing .what should i do ??? Have MFC -790 cw all rest collor printing good only have problem with black one .
Did you use Brother Genuine Cartridges?????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
If you are using Generic, replace them with Genuine Brother Ink Cartridges.
Good Luck
Jan 29, 2010 | Brother Multi-Function Center MFC-240C...
Then your point is i should buy a new set of color cartrages like the 3 colors before the printing should take place then how can i set my brothers printer mfc-240c into black cartrages only no need to buy...
First - read the manual as regards printing. I notice that you can print in Black and White but I cannot find anything to say that you only need the Black ink to do this (therefore I think that I am right in saying that you need the colour cartridges).
Question - Has it worked with only the black ink before now?
As a final solution - Contact Brother direct and check out their FAQ's and/or send them an email asking if you can run the printer with Black ink only installed (I suspect the answer will be no).
If the answer to the above questions comes back as "Yes you can use Black only" (they may tell you how to set this up in which case ignore my next comments), then please supply some more information as regards what happened immediately before it stopped printing. This will help to drill down to the problem.
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
