Vocopro DVD-Duet 80W CD / Dual Cassette / AM / FM Karaoke System Shelf System Logo
jane Posted on Jul 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clean cd-g lens - Vocopro DVD-Duet 80W CD / Dual Cassette / AM / FM Karaoke System Shelf System
Anonymous
Level 3:
  • Vocopro Master 6,771 Answers
  • Posted on Jul 09, 2012
Anonymous
Vocopro Master
Level 3:
Answers
6771
Questions
0
Helped
1777313
Points
21413
You can purchase a cd cleaning kit with instructions to clean the laser lens.
1helpful
2answers
Can I use contact lens cleaner for CD DVD player lenses
No, you shouldn't clean your CD/DVD player lenses with contact lens solution. It is inappropriate to put contact lens cleaning on the CD/DVD player's lens because it is made for the delicate surface of the eye. A CD/DVD player's lens can become harmed and malfunction if contact lens cleaning is applied to it.
Use a soft, lint-free cloth and a cleaning solution made especially for CD DVD players to clean the lens if necessary.
1helpful
2answers
2000. Why doesn't it play a CD and indicates ER6?
Did you try to clean the lens of your optical reader? A typical product is selle dy Amazon and most retail stores
Memorex CD and DVD Lens Cleaning Kit
Tutorial to use a cleaner is shown in youtube
How to Clean CD DVD Laser Lens in Computer
How to clean DVD or CD player or recorder lens Sony RCD W500C
how to clean car audio player
and much more, just do a google search for
Youtube Clean Car DVD Lens
2answers
CD tray opens and shuts fine. With CD loaded and shut the screen still says NO DISK. These are disks which have always played without problem on this CD player. Is there anything I can try before taking...
When the CD player loads properly and still reads as no disk this indicates that the player lens (Optical device which reads the disk information) Is either dirty or bad. The only option you have is to get a disk lens cleaner and run it on the system. Once you run it, it is supposed to work if the lens is not spoilt. Otherwise you will just have to replace the lens by taking it to a repairer.
Hope this solution has been helpful?
1helpful
2answers
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • 0helpful
    Am getting code e-04 which manual says is dirty cd remove and clean ive looked at all cds and all appear speckless
    The CD lens may be dirty. If you have a CD lens cleaning kit or a CD-rom with a cd lens cleaning brush, I suggest you try either of those. Don't use a paper towel as they can be quite abrasive to a delicate CD lens. If you have camera lens cleaning equipment and can see the CD lens (use a flashlight), you may attempt to gently clean the lens with the camera lens cloth and solution.
    3helpful
    2answers
    CD player does not recognize the cd's in the player
    Hi, you will need to replace the optical lens assembly asap if possible. this is basically what the issue is at Thia's time. you can confirm my diagnosis by trying to clean the lens with a lens cleaning disc. if the cleaning dosen't restore the reading ability of the lens, you will need to replace the optical lens assembly when possible.
    please rate and have a great memorial day:)
    I hav lg dvd writer it plays cd but dvd what to do
    That is because of a dirty or defective lens. When you have a lens problem the unit may still play CD but not DVDs.
    Try first using a lens cleaner disk, like the ones here.
    If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
    How to Clean the Laser Pickup Lens on your DVD Player
    How to safely clean a DVD lens?
    Clean DVD lens, or replace player?
    Clean CD or DVD ROM lens with a brush?
    Cleaning your DVD drive
    How to clean a DVD player
    2answers
    Plays cd's but lots of skipping going on. I tried cleaning with a CD player disc cleaner that I got today. That didn't help. None of the CD's skip in another machine. Thanks!!
    When optical lens got dusty or thin layer of dust on lens, cd starts skipping, as you tried cleaning with lens cleaner cd but no result.
    You need to open the unit and clean the lens with good quality cotton bud / swab with care.
    Still no joy, replace optical lens.
    Cleaning lenses
    Hello sir,
    Buy a good and branded Cd Lens Cleaner CD and put into cd player and play it.... It will clean the CD lens properly... try it
    BEst of luck
    Cheers!!!!!!
    Top Vocopro Audio Players & Recorders Experts
     Grubhead
    Grubhead
    vince
    ADMIN Andrew
    ADMIN Andrew
    Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
