Question about RCA F25254GY 25" TV
Power on problem
The set powers off after a period of time.right before shut down it emits a whining noise from the rear of the set and continues after it has shutdown.I'm not real good at trouble shooting, but if there is a specific fix, like a cap or something, i can fix.I just need a little direction.I'd appreciate any input.
    Novelist:
    Champion:
  • 236 Answers
You might have a cap that shorts after it heats up causing your problem. The whinning sound you hear sounds like the power supply has a short on it. Usually when this happens though, it doesn't go away until some part such as the horizontal output transistor is replaced. RCA's are notorious for flybacks shorting and then shorting the horizontal output transistor. Your flyback may be shorting intermittently. Strange! Stargazer
Posted on Mar 03, 2007
Power steering whining, sqreeching
hi Eva.
As you turn your steering wheel it is this fluid pressure that aids in turning the wheels of your car. ... If the pump impeller is trying to move power steering fluid and starts catching air bubbles it can cause whining noises and vibrations to occur.
Maybe you've heard it at a stop light. Maybe you've heard it as you pass a car on the freeway. Or maybe you've heard it in the parking lot at work when someone is leaving. The unmistakable whine of a power steering pump can make even the most confident mechanic wonder when that car will breakdown.
Power steering pump noise is a unique noise that your car may make and once you've heard it you always know what it is. The noise is a mix of a whirring and a whining and will always vary with the speed of your engine whether your car is driving or in park. This whining noise can be subtle or extremely loud and may be worse in colder weather, or right when you first start your car.
Power steering pumps are most often vain style centrifugal pumps that are tasked with pressurizing the power steering fluid and pushing it down to your power steering gear or rack. As you turn your steering wheel it is this fluid pressure that aids in turning the wheels of your car.
There are a few reasons why you are hearing power steering pump noise from your car. First, it may simply be due to the design of the pump. Sometimes, noisy power steering pumps can continue to work flawlessly for years after they start making noise. This may simply be due to the manufacture's design or a tight tolerance in that particular pump. In this case, you would hear the noise but not see any other adverse effect like a loss in power steering, leaking fluid or a wobbly pulley. In this case, you may be able to help reduce your power steering pump noise by choosing a different type of power steering fluid, like a synthetic fluid.
Your power steering pump may also be making noises due to air trapped in the system. If the pump impeller is trying to move power steering fluid and starts catching air bubbles it can cause whining noises and vibrations to occur. Even tiny air bubbles you cannot see that are trapping in the power steering fluid may be causing the whining you are hearing. In this case, the best thing to do is flush your power steering system to try and remove the air from the system. Having air trapped in your power steering system can be difficult to diagnose so you may need to simply try a power steering flush to see if it solves your problem.
Power Steering pump noise may also be due to a failing power steering pump. As the bearings on the impeller go bad it will start to make noise as the pump is turning. If you have a bad power steering pump you usually will also experience leaks from around the pulley, a wobbly pulley, or difficulty turning the steering wheel when you are stopped. If you have multiple of these symptoms together, it is probably time to replace your power steering pump.
Lastly, and most usually, a whining power steering pump is an indication of a low fluid level. Your power steering fluid is probably something you have rarely if ever checked, so it often comes as a surprise if the level is low. Your power steering fluid reservoir is also relatively small so even a slow leak will cause a low fluid level relatively quickly. To confirm this is your problem it is as simple as checking your power steering fluid level. Some power steering reservoirs are clear so you can see through them to check how full they are. You may have to wipe away some dirt and grime to find the "full" line, but it should be easy to check. If you have an opaque power steering fluid reservoir there should be a small dipstick under the cap that will help you measure the fluid level. If it is low, then you have a leak somewhere and topping off the fluid should quite down your power steering pump.
If you discover a power steering leak, rather than simply continuing to add fluid every time it gets low, you should fix the problem permanently so you don't have to continue to check your power steering fluid level. Replacing lines or seals can be a surprisingly difficult task due to the location of your power steering pump and steering gear or rack. The easiest way to seal your leak is to do it from the inside out!
or check this link out for more info on this matter.
Power steering whining sqreeching Google Search
Dec 14, 2017 | Cars & Trucks
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Whining noise from front end. starts at 5mph and
If the sound is coming from your power steering pump and the fluid level is good, the pump could be going out.
Oct 12, 2009 | 2001 Dodge Dakota
Whining noise on start up, lamp and TV shutting down
The TV tech isnt too familliar with RCA TVs. The color wheel is the most likely problem no where near 1000. Depending on the model number of your set you can get replacement color wheels at the following link.
http://servicemanuals.vstore.ca/
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
2004 Grand Cherokee Whine - What is the Problem
It sounds like your power steering fluid is low. When the fluid is low there will almost always be a constant growl coming from the pump. Worst case - it may be the pump itself going bad. . I own 3 Jeeps but have only had this problem on my 87 Cherokee.
Ford PS pumps are notorious for making noise as they get old, but they still seem to work ok. This may be the case with your Jeep. If the PS still works and the fluid level is normal, it may just be a matter of whether or not you can stand to listen to the noise.
Jan 04, 2009 | 2004 Jeep Grand Cherokee
I have a Pioneer Elite PRO-940 - problem exists when the tv is powered off - a component (might be a power supply or transformer) kicks on within a second or two after being turned off - emits a low...
Hi-
Do you have a receiver attached to your devices? make sure that components are as well of since its creating a background noise on some devices, check the cables as well.
Thanks for using fixya, keep us posted for any progress.
Jul 16, 2008 | Pioneer Televison & Video
I have an RCA model #HD50LPW62AYX2 hdtv/dlp rear-projection set. The picture went out, and we thought it might be the bulb, so replaced it. The picture still will not come on, and there is a loud...
The color wheel can make a whinning sound for sure, However it should not continue to whine after shutting it off. That sounds more like the fan used to cool the lamp, as that will continue to run after the set is shut off. How soon does the whinning start when you push power? Let me know I should be able to help you out. DLPs are my specialty
Mar 26, 2008 | Televison & Video
No picture
My too, same problem - tried replacing lamp ($150), no luck, replaced ballast ($200) no luck, replaced power supply ($150) no luck and TSC is telling me to replace the main engine ($600) - way too much for this piece of junk (cost me $4000 in 2005) - don't buy optoma products!!!
Nov 11, 2007 | Optoma RD65 65" Rear Projection HDTV
200 gb d2 extreme
The whining noise and the low clicking sound are indicate mechnical problem. My recommendation to you is to backup all the important data you have on it ASAP before it will crash and you will not able to do it !!!!
Aug 27, 2007 | LaCie (300950) 400 GB Hard Drive
RCA F25254GY 25" TV Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
