Question about Canon PowerShot A610 Digital Camera
Cannon A610 + water = Print/Share button blue light !
SITUATION:
Ok. I was traveling and put some of the water I got on the plane in the same bag pocket where I had put my A610 (in retrospect...duh!).
The water from the sealed plastic cup did leak and get into my camera. I tried turning the camero on after wiping off most (but not all) of the water. I have let the camera dry off for more than 1 week now, but still each time I tun it on, the Print/Share button lights up in blue color...nothing else happens!
When the leak occured, I had Ni-Metal Hydride batteries in the camera and the water did get into the battery and memory slots. I did replace the batteries with regular alkaline bateries and for a second the camera did turn on (ie, Lens exposed, LCD turned on) but died quickly. So now my camera has an exposed lense. The Print/Share light issue remains.
WHAT I HAVE TRIED:
I have downloaded and searched the A610/620 manual to see if it tells u what the Print/share blue light might mean...but nothing specific there. I have also tried pressing and holding the power button, menu button and other buttons and also tried some combinations to no avail.
CAN YOU HELP?
I suspect my beloved A 610 is a goner, but I'm hoping it's a study lil bugga!
  • amdMcBook Jan 02, 2009
    That may have helped a bit. The camera at least turns on and I can even take some pics in certain modes, but the buttons are all messed up....they are too senstive and dont work as expetced.
    I ended up buying the newer version A 630 (8 mega px, larger lcd). Overall I am satisfied. Thanks for your help
    Problem Solver:
  • 18 Answers
Depends on how old your water ingress problem is.
If it is a recent problem, half fill a bowl with rice place your camera in it and cover the entire phone is rice, bury it.
Rice is hygroscopic and will absorb moisture from the camera.
No guarantee that will work though. Corrosion doesn't need much convincing to get going.
Posted on Dec 09, 2008
Cannon MP990 C610 error
Inkjet cartridges dry up very soon. You have to use it everyday. Or clear the nozzles using hot tap water soak. Or try new cartridges again.
Apr 03, 2012 | Computers & Internet
Cannon A610 shuts off when i push button to take photo
OK, long shot, but you never know. Press the top cover dowsn when you shot a photo. If camera is not powered off, then fasten the 3 screws that you may find at the top of the batteries housing unit.
Feb 21, 2012 | Canon PowerShot A610 Digital Camera
Air hogs jet set plane won't charge
This situation happened to me too after using it like 10 times it doen't
charge anymore does anyone knw what to do and what is the neutral position for the rudder how does it have to do with charging the plane I know what the rudder is and where it is ,ut don't know how to put it into neutral position.Help???
Jan 20, 2012 | Master Heaters Air Hogs Jet Set Assortment...
Will a 16gb SDHC card fit in and work in my Cannon Powershot A610 camera
No. The A610 works with MMC and SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
May 24, 2011 | Cameras
Can't transfer photos to computer. After proper connection, the blue light does not come on. Have checked instructions on both camera and computer. what else can I do on my Canon Power Shot A610 to...
Assume that each devices either computer or camera were within functionality also requiring a compatible cable connector device to provide media distribution. In such a situation, connecting each device as camera has prior media that requires transferability makes attainment explainable. Once connected depending on camera prior features would require buttons that initiate the media transfer process. In a situation where computers that are media compatible either as customized with programs that capture or detect any available resources would automatically display transfer mode to resource between computers. Each device of camera or computers requires familiarization to attain functionality. Refer to camera user guides to ascertain the media capture to computer expiries expectations. Also familiarize with the compute to ascertain the methods available to capture an experience.
Feb 24, 2011 | Canon PowerShot A610 Digital Camera
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
Live view shooting/print/share button stuck on
Until you figure it out, pop out the battery until you use it next time. I have not used this feature. Do your recall how you turned it on?
Dec 26, 2009 | Canon EOS 50D 15.1MP Digital SLR Camera...
Canon PowerShot A610 Digital Camera Logo
101 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
