Question about Samsung S850 Digital Camera
Samsung s850 cant copy from camera to sd card?
Hi i took photos on my camera without the memory card and now i need to transfer them onto the memory card, is this possible?
The Samsung S850 has an internal feature to do this. I have one. Put in your memory card and turn on the camera, push the button on the bottom right hand side of the lcd screen to view the picture, next when you see a picture (it can be any picture) push the OK button, this brings up a set of commands across the top of the screen, as you go across the commands one of them will be "copy to card". Select yes and the camera will copy the pictures to the card.
Posted on Jan 12, 2009
    Problem Solver:
  • 18 Answers
As the images stored on the camera are on a "drive" the only way is to connect your camera (minus your memory card) to your computer, wait for the drive to show up, browse to said drive and move the pics to your computer.
Then replace your memory card and move the pics to the memory card of use a card reader to copy the files across.
Posted on Dec 09, 2008
Camera will not allow me to "copy" photos to transfer from internal memory to SD card?
You may be able to connect the camera to a computer and access the picture files that way. Also make sure the SD card isn't close to full.
Jan 01, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
I have a panasonic lumix DMC-FS7. Used it for many years with 4GB SD card insitu. Recently took some precious photos and am trying to copy photos from camera to PC. When I plug the camera into my PC it...
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Feb 04, 2013 | Panasonic Lumix DMC-FS7 Digital Camera
Transfer pictures from camera to memory card
Put the card into the camera. Press the Playback switch to get into playback mode. Press the MENU button to bring up the menu. Select the Copy command.
Aug 17, 2012 | Nikon Coolpix 4800 Digital Camera
Pentax E85 PC connection fail
Put the card into the camera, use the "Copy" command in the Edit menu to copy the two photos onto the memory card, and then transfer the photos to your computer as you usually do from the memory card.
Apr 01, 2012 | Cameras
Hi, i have some photos on my internal memory and need to put them on an sd card because the connection with usb is faulty. As soon as i put an sd card in camera i cant see internal memory images. Is...
There should be an internal transfer from memory to SD card on most camera but not all look under the main menu for the memory card where it tells you to format card and create folders it there should be a COPY option.
Dec 06, 2010 | Pentax Optio A10 Digital Camera
How do you transfer internal memory pictures to memory card? I have a Samsung Digimax L60 camera and I forgot to put my memory card in my camera and took pictures without it in. How do i transfer the...
Put the memory stick inside the camera. Then open the photos which is save in your camera memory. Select them all & then you find a option Send to memory card or copy to memory card. Select that and press ok. Your photos transfer from camera memory to memory stick.
Thanks
Dec 30, 2009 | Samsung Digimax L60 Digital Camera
Transfering images to SD Storage card
I'm not familiar with your camera but most of them have a listing in the menu for "copy" with instructions on how to transfer from the internal memory to the memory card.
Nov 17, 2009 | Samsung Digimax D53 Digital Camera
SD Card Issue
Usually when you take pictures using NO SD card you can't take the picture, however in this case the pictures you took are stored in a memory bank temp only to test the picture your actually taking. In the manual what's the size of the built in memory card? Usually it's small amount of memory built in
Sep 07, 2009 | Samsung Digimax S730 Digital Camera
Can't transfer internal photo
You can copy the pictures from the internal memory to the memory card as described on this page of the extended user guide.
Jun 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Need to put Pictures from Camera onto Memory Card
Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
Feb 14, 2009 | Kodak EasyShare C330 Digital Camera
Samsung S850 Digital Camera Logo
202 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
