Someone changed the at button on my keyboard ,how do change it to default settings
  • Peter Sturniolo
    Peter Sturniolo May 11, 2010
    What do you mean by changed? When pressing Shift+2 you don't get the "@"?
Tray changing your keyboard type from englis to usa or visversa
Posted on Dec 09, 2008
How To Change The Default Keyboard Layout in Windows 7 and Windows Vist
Having problems with your keyboard?
How to change your default keyboard layout within Windows 7 and Windows Vista.
This is a keyboard problem that a lot of non US computer users run into when using a new computer or one that is newly formatted.
Users find that some of the keys on the keyboard don't seem to match what is appearing on the screen in front of them when pressed. The two main keys are the @ and "(2) which switch places.
What is happening is that by default, Windows will setup a US keyboard layout at install which when used on a physical UK keyboard doesn't match up the @ and ".
This is a really quick and easy problem to solve which just requires a couple of settings to be changed within Windows.
This walkthrough is for both Windows 7 and Windows Vista. Changing keyboard setting is the same process in both versions of Windows.
Please make sure that any important data you may have on your computer is backed up before following this walkthrough or video!
  1. From the Windows desktop left click the start button
  2. On the start menu left click Control Panel
  3. In Control Panel left click Clock, Language and Region
  4. Under Region and Language, left click Change keyboards or other input methods
  5. In the Region and Language dialog box left click the Keyboards and Languages tab
  6. In the Keyboards and Languages tab left click Change keyboards...
  7. On the general tab that opens left click Add
  8. Look down the list and find English (United Kingdom)
  9. Expand +English (united Kingdom), then expand +Keyboard
  10. Tick the box next to United Kingdom then click OK
  11. In the default input Language drop down list, left click English (United Kingdom)
  12. Left click Apply
  13. Left click ok
on Jan 17, 2011 | Computers & Internet
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
Keyboard types wrong characters
You may have a wrong default keyboard layout.
To resolve this please do the following:
Assuming you are using Windows 7, click Start->Control Panel, and then go to the "Clock, language and region" icon, and click on the "Change keyboards or other input methods" link.
When the window opens, click the "Change keyboards" button.
When the window opens, check the default input language. Assuming you are in the U.S. If it doesn't say "English (United States) - US" then you need to change that by highlighting the wrong language, and clicking on the "Remove" button.
As a last step, restart the computer to make sure the settings are applied.
Jun 24, 2011 | Sylvania GNET28001XSN Netbook
é comes up when i try to press the key for a slash
I believe you have the wrong keyboard input language installed as the default language.
If you are using Windows Vista...
1. Open the Control Panel. (Classic View)
2. Click on the Regional and Language Options icon.
3. Click on the Keyboards and Languages tab.
4. Click on the Change keyboards button.
5. To Select a Default Input Language, under the Default input language section, click on the drop down menu and select a language (English (United States) - US?).
6. Click "Ok" and try your keys.
If you ar eusing Windows XP...
3. Click on the Languages tab.
4. Dlick the "Details" button.
5. In the windows that opens, choose the "Settings" tab, and change the "Default input language to "English (United States) - US", and make sure in the window below, the Keyboard is set to "US"
6. Click "Ok" twice and try your keys.
Sep 19, 2009 | Acer Aspire 4720 Notebook
Laptop key board are messd up
If you have changed the keyboard type in 'regional and language options' you can manually pull of the keys and stick them back on where they should be. It sounds like someone has done that to your keyboard so no regional setting could fix this.
Instructions for Windows Vista
Click Start and then Control Panel In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner) Open Clock, Language, and Region Click on Regional and Language Options. Click the Keyboards and Languages tab and then click Change keyboards. Under Installed services, click Add. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Apr 16, 2009 | Computers & Internet
Keys on keyboard not working properly
go control panel, hit mouse and find default settings. hit default, ok and do a reset on your computer.
If you have a special install disk for your mouse when the system starts back up ,test your keys then install the disk(or CD). if this does not correct your problem , check to see if someone changed the language on your pc. If english, buy a new keyboard.
Jan 31, 2009 | Computers & Internet
Dell Inspiron 6400 keyboard types " when you select @ how do I change this?
you have the wrong keyboard settings,
i trust you are using windows, you need to go into control panel, and find regional and language options, when the new window options take the second tab (languages)
press details button and check you keyboard settings .
you may need to add a new keyboard and delete the current one.
if you have just installed you operating system it is set to the default settings, if it has been installed for a while but has only just had this problem maybe someone changed the settings.
you may even be able to change settings using the language bar at the bottom of the screen.
Dec 27, 2008 | Dell Inspiron 6400 Notebook
Change default button settings
Normal 0 Go to Control Panel and click on the Mouse icon. When the window opens showing the mouse, select the button you want to change and click on the drop down and set as desired.
Hope this helps. Bud
Nov 14, 2007 | Logitech Marble Mouse Trackball
Computers & Internet Logo
David Payne
David Payne
