Question about Cooktops
Ceramic hob will not work`
Have just fitted new hotpoint touch control ceramic hob. it came on briefly for a second and has not worked since. have tried re-wiring but nothing has worked.
  • Barry Coates
    Barry Coates May 11, 2010
    Have you got any warning lights or any display of any kind? i
  • 1462 Answers
SOURCE: Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Posted on Jun 06, 2007
  • 135 Answers
SOURCE: Unlocking our touch sensative hob
Try pressing and holding the unlock key for 10-15 seconds.
Posted on Apr 07, 2008
SOURCE: got a diplomat ceramic hob with no instructions
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
Posted on Mar 05, 2009
  • 254 Answers
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Posted on Feb 06, 2010
SOURCE: Stoves 700CTH hob
Hi, this worked for me as well on a 900CTH. Has to be a design fault judging by the number of people with the same problem.
No idea what this capacitor does but a guess would be that it is the reset circuit for the processor. This is normally a simple CR circuit which holds the reset pin down so the processor resets on power up. Only in this case their design does not hold the pin down long enough hence increasing the capacitor from 220 to 1000 micro-farads increases the time constant so that the pin is held down long enough. The installed value probably works well initially but due to the heat on the hob the capacitor ages, capacitance decreases in value (a common issue with electrolytics) and low temperatures at start up exhibit lower capacitances hence the fault is, as reported, worse in cold conditions. So my additional advice would be to pick a replacement with a high temperature rating.
Posted on Apr 07, 2010
Hotpoint ceramic hob willnot turn on power is on hob just dead
If the lights are coming on there is a great possibility that your plate needs replacement. Unfortunately electronic items usually don't come with any warranties, so make sure it is the plate before purchasing a new replacement. Regards bandha
Oct 05, 2017 | Cooktops
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Got a diplomat ceramic hob with no instructions
Jan 14, 2009 | Cooktops
Apr 05, 2008 | Cooktops
Cooktops Logo
147 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
