Question about HP Compaq d530 PC Desktop
Hy hp d530 won't turn on
I turn the power button on and nothing happens. The green light on the mother board blinks, but nothing else happens. the fans don't go on either. i've unpluged everything and it still won't turn on. a friend suggested that the memory slot is defective so i should replace the motherboard. this is a refurbished machine and is only a couple of months old.
help please
thanks
  • 20 more comments
  • ngibbs691 Dec 09, 2008
    NO sorry no sounds at all. If i keep the power button in it will flash and the green light on the motherboard would keep on flashing.
    no beeps an led blinks green.
    voltage is set at 110v. the lights on the keyboard don't blink. the green led on the motherboard blinks. If i keep the power button in, the power on light would blink (green) as well. I tried unplugging everything to check if any particular item was causing the problem, but i got the same result. Monitor says no signal and pc does not turn on.
    i tried both memory chips, the 512 and the 1gig and got the same result.
    no i don't but it's a 2.8MHZ up to 4gig pentium 4. i have the slim model not the micro tower. i bought it on comp geeks, it's a refurbished machine.
    yes that's correct it is a 4 dimm. I have 1 512mb and 1 1gig so totaling 1.5 gig ram. it's a 2.8mhz processor.
    Speed of memories are 512 and 1gig.
    I did pull out the battery and out it back, no change.
    i also pressed the cmos button, but it did not do anything.
    Thanks Jonathan, it worked fine for a couple of months. one day it was turned off and the rest is history. i did experience a couple of power outages a week or so before, but don't get any scent of burnt electronics from the pc.
  • ngibbs691 Jan 06, 2009
    don't have the cd. i was told the memory slots my be burnt, does this sound right?
  • Anonymous Mar 15, 2009
    My Compaq d530 was running fine until one day during plugging in a USB device (MP3 player) the system completely stopped working. The only thing which is active is the green LED on the mainboard.
    I have checked several things and have found the following:
    - IDE cable had burn marks!! (nasty)
    - USB connection cable which runs from the front to the motherboard has changed in color. (darker green while all other connector have e more light white color.)
    These are the signs of a brun out, but I do not have any solution to repair this.
    Economically the best thing to do is buy a second hand (or new) system. (d530 are about 60 euros these days (march 2009). Hardware parts can maybe salvaged.
  • Gary
    Gary May 11, 2010
    From what I recall, each memory bank pair must have memory chips of the same size. Thus, if you have a 1Gb and a 512Mb chip, then this would present an issue for the system. I don't know if that means it won't start at all. Did you try booting up with just one chip installed, in slot "0"? If you tried this, once with each memory chip, then you likely have a faulty motherboard. Motherboards are too expensive to fix--you just replace them. I don't know what the rest of your system is like, so you'd have to decide if there were enough usable components inside to warrant replacing the motherboard. You would also want to do this privately, as taking it to a service center will likely end up costing you more than if you went out on CraigsList and acquired a used and well working computer. Good luck!
  • Gary
    Gary May 11, 2010
    If your power supply had completely failed, you would not get any power whatsoever. So it sounds to me like it may be OK. Were you able to get any further? If not, I suggest trying to boot from a rescue or installation CD. If you can boot from that, then your issue might be your hard drive.
  • Solo4665
    Solo4665 May 11, 2010
    I suspect that those memory modules are not supported by the motherboard, but it's hard to be sure without knowing exactly what motherboard you have.
    Checking the web I find this
    http://bizsupport2.austin.hp.com/bc/docs...
    Which on page 17 states that the D530 motherboard does not support memory modules beyond 400Mhz. I appreciate that this isn't exactly the same model of D530, but the HP support forum had a comment on from a HP guy saying that the only difference is in the positioning of things like USB ports etc..
    Therefore, a question I probably should have asked at the outset... "has it ever worked since it was refurbished?"
    If the answer to that is "no", then I think somebody upgraded the memory on the PC during refurbishment, and put in the wrong modules.
    Can you let me know what you think of this idea please?
    Thanks,
    Jonathan
  • Solo4665
    Can you tell me the speed of the memory modules please?
  • Solo4665
    Another idea.. can you take out the CMOS battery, leave it out for say a minute or so, put it back in, and then try to power on again?
    It looks like a silver, flat coin. Kind of like the batteries you get in watches.
  • Solo4665
    I think you should have 4 DIMM (Memory module slots). They should be colour coded, blue and black.  Can you confirm this please?
    Also, can you tell me the speed of the DIMMS that you have? there is normally a sticky label or something on them like 333Hz.
  • Solo4665
    What sort of motherboard is it? Have you got a part number?
  • Solo4665
    Please try taking out the memory chips, and then testing to see if it boots with each memory chip in turn. (i.e only 1 chip in at a time)
    Also, can you ensure the processor is secure in it's slot by pressing down gently on it.
  • Solo4665
    Looking at page 14 of the manual - what can we learn from the keyboard LED's? ie. has the rom failed?
  • Peter Sturniolo
    Peter Sturniolo May 11, 2010
    Is the power supply set to the correct voltage? Should be 110V in the US, 220V just about everywhere else; make sure you unplug the power supply before changing any settings.
  • Solo4665
    Are there any beeps from the machine?
    Does the LED blink red?
    This may be a useful starting point..
  • Peter Sturniolo
    Do you hear any low pitched beeps when turning it on? That would indicate a problem with one of the memory slots/memory itself.
I have a similar problem:
Posted on Mar 15, 2009
    Sergeant:
    Champion:
  • 426 Answers
Check your power supply
Posted on Dec 09, 2008
Suddenly my hp pavilion a1217n tower won't turn on...the green light is blinking rapidly...
are you referring to the light on the back? if so the power supply has most likely failed, mother board can also cause this issue.
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
My computer is hp compaq d530 SFF when I turn it on nothing starts only green light blinking on the logic board. Please help me solved it.
It sounds like the power supply is defective and will need to be replaced.
I hope this helped.
Good luck and have a great day.
Jun 21, 2011 | HP Compaq d530 SFF PC Desktop
Hp pavilion a820n comp won,t turn on . rear power light blinking , turned all power off several times waited long intervals before repowering unplug all plugs and tried still no power up found when mother...
make sure nothing is plugged in to your front card readers slots:
If so PC will not boot. Other then that can you put a different power supply in it? Just to see if it is the Power supply..
Jul 26, 2010 | HP Pavilion A820n (PP165AA) PC Desktop
Need help with motherboard power connection wiring.
i have no mother board cd then system is formatting is not possible please help me i want drivers cd
Apr 11, 2009 | Compaq Computers & Internet
HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Mar 06, 2009 | HP Compaq d530 SFF PC Desktop
Compaq d530 wont turn on
hello there,
that is motherboard problem. sorry to say i believe that system was dropped. at some point.
Dec 05, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Blinking green light on the back of hp pavilion
1. Your smps is OK for power supply
2. check the beep sound for RAM and Video card (If it is long beep the RAM is having and short and frequent the Video card) o
3. Remove RAM then start ssytem see the response shoutdown, clean the RAM place it back start the ssytem
4. Remove the CMOS battery or short the jumber for any setting in BIOS start the ssytem
5. Disconnect all the cables connecting motherboard including Hard disk except SMPS power supply to Mother board
Jun 22, 2008 | Computers & Internet
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
OR
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
Power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Nov 26, 2007 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
HP Compaq d530 PC Desktop Logo
1,573 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
