Question about Acer Aspire 5600 Series 5630-6951 Laptop
My mouse scroll 4 way button on my laptop doesn't work and when i go into mouse properties it says synaptics pointing device driver not there- not sure if they are related.
  • swing320 Dec 14, 2008
    I re-installed vista to my aspire 5630. Now my 4 way scroll and vol+, vol- buttons don't work. Forums say to go to www.acer.com. It's not that easy. I go round in circles trying to download drivers....................AAAAAAAhhhhh!
I've solved this problem....
Goto acer, http://support.acer-euro.com/drivers/notebook/as_5630.html
under the windows vista there's a drop-down box "Driver and utilities"
open that and go for the third from the bottom "TOUCHPAD SYNAPTICS"
just download that and follow the instructions.
I've just done it and got my scroll button back.......
Posted on Apr 23, 2009
  • 117 Answers
Looks like your mouse/pointing device driver isn't correctly installed. You can download latest drivers from acer support page www.acer.com
Posted on Dec 09, 2008
My logitech wireless mouse for my laptop stopped working today. The green light still comes on, but the mouse appears to be frozen. I checked the batteries, tried the reset button, made sure it was turned...
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps you
Aug 07, 2011 | Computers & Internet
I have a usb wired dynex optical mouse, i just bought a Toshiba sattelite laptop and external mouse does not work when i plug into usb port
Windows 7
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a buuon or switch on top or bottom
hope this helps
Jul 01, 2011 | Computers & Internet
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
I just had windows 7 installed on my laptop, now my mousepad won't scroll. how do i fix this?
Hello
you probably haven't installed the touch-pad driver yet. go to the computer manufacturers website and look for the touch-pad driver that is specific to your laptop
Also I would say that it is a setting in your control panel if you have used any other mice or install another mouse drivers it may have affected you touch pad. I would suggest looking at the synaptic setting and see if there is an option to set the touch pad to default settings. If all else fails you can try to reinstall the synaptic drivers from the laptop support site. I hope this helps.
Feb 17, 2011 | HP P2350AA Mouse
My synaptic pointing device stop working ..I think
Since you do not specify the model number for your HP laptop one cannot be too specific. On my Toshiba laptop activation and deactivation of the touch pad is enacted by pressing the Fn-F9 sequence.
The actual Function key to press after the Fn key might have the picture of a touch pad on it. Examine tour laptop keyboard.
Jul 06, 2010 | HP Computers & Internet
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
I downloaded the synaptic mouse touchpad driver - and can no longer scroll up or down the screen without holding down the left click button. please help
Right Click the Synaptics Pointing Device Icon on your Task bar tray, click POINTING DEVICE PROPERTIES,it will open the Mouse Settings, Click the Wheel Tab and make changes as you want it
Thanks
Oct 25, 2009 | HP Compaq nc6220 Notebook
Vertical scrolling not working
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
May 22, 2009 | Compaq Presario CQ60-220US PC Laptop
Synaptics touchpad totally dead no response!
Right click the Synaptics Pointing Device and select Pointing device properties OR double click the Synaptics Pointing Device. A Mouse Properties Dialogue is displayed, then select the Device Setting Tab and then select the synaptics device under device section then select the enable button and lasting select the the Apply button.
Jul 08, 2008 | Computers & Internet
Inoperative touchpad scroll zone
rwertheim,
I have a MX8711.
I assume you are running Vista.
After you have updated your virus protector program and run a complete scan. You "could" be fixing it and if it is a virus problem, it is immediately reinfecting the driver. If it still doesn't work, I recommend you:
1. Rollback the driver of your touchpad. If it was working, this might do the trick. You can do this at Control Panel > Mouse > Hardware (tab) > Properties (button) > Driver (tab). If it has been updated and that caused the problem, you probably can "Roll Back" to the previous driver and that option will be highlighted.
2. If not, then your driver is probably corrupted. Go to Gateway Support and download the touchpad application file for your computer and SAVE IT TO YOU DESKTOP AND DO NOT RUN IT. Replacing only the driver usually doesn't work in these cases but try that first. Go to Control Panel > System > Device Manager > click on the (+) sign by mice and dbl click on the Symantics PS/2 Port Touchpad (or what ever yours is) > Driver (tab) > Uninstall. When you restart, it should reload the driver from the application that is still installed.
3. If that dosn't work, I recommend uninstall the application from Control Panel > Programs & Features. Restart your computer and install the application you saved on your desktop.
I hope this helps.
Have a blessed day.
Tracker Tom
Apr 09, 2008 | Gateway MX8711 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
