Question about SanDisk 2GB microSD Memory Card
Sd format error - SanDisk 2GB microSD Memory Card
  • Anonymous Apr 08, 2009
    my micro sd can,t format...
  • Anonymous May 07, 2009
    my microsd 2gb is not getting formatted
    Scholar:
  • 162 Answers
Memory card corrupted. you should buy new one.
Posted on Dec 09, 2008
I can not formate my SD memory card it shows windows was unable to formate
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
Dec 21, 2013 | Electronics - Others
In my Nokia 5130c-2 mobile I've a 8GB Micro SD memory card. When I try to enter into Memory Card it tells Unknown File Format in Memory Card. Format Memory Card Yes/No? Every thing was going fine...
Put the SD card in a stand alone card reader, and copy the data off it to your computer. Next, format the SD card, and put it back in your phone.
May 06, 2011 | SanDisk 2GB microSD Memory Card
My micro sd 1gb was formatted but the card appeared to have 0kb space available, what should i do/
The most common thing that causes these problems is that an Incorrect format was done on the disk. Here are two different ways that you can fix these errors. I will give you the step by step way to fix them on each one.
First Way To Fix Your Issue:
  1. Stick the SD Card back into the Card Reader on your Laptop or Desktop Device.
  2. Open My Computer.
  3. Right Click on the SD Card.
  4. Select Format.
  5. Format window pops up.
  6. Under the Drop Down Menu of File System Select NTFS.
  7. Then Click Format Wait till it finishes.
  8. Then you should be done and the problem fixed
Second Way To Fix Your Issue:
  1. Stick the SD Card Back into your Phone or Camera.
  2. Select the System Settings on the device.
  3. Select format SD Card on your device.
  4. This should fix the issue.
If you are still having problems with this card then the SD Card is probably bad and needs to be replaced.
Apr 23, 2011 | SanDisk 1GB microSD Memory Card
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
My files in the teac 1gb sd card cannot be delete or remove, i tried to format the sd card be error message says cardis write protected
This card will be formated by ms-dos command first you open dos window then type a command format e: enter key.
Nov 06, 2010 | Electronics - Others
Cant format sd card shows error ioctl
Have you tried to format this unit on another computer. If you get the same error on another computer then it is a bad sd card.
Oct 29, 2010 | Electronics - Others
I am not able to format my micro sd card.
try to format it using ur phone.. if still showing sum error thn card is corrupted.. it will be replaced
Sep 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
SanDisk 8GB microSDHC has an error that tells me i need to format it. so i use Panasonic SD formatter and when the process is done it says completed but when i go to open it up it says it still needs to be...
umm You will get a ready adapter through which you can connect your memory stick to computer directly . Format it ...
I have no idea about panasonic SD formatter . But basically your SD card has a lock to one of its corner . try to unlock it and retry formatting .
This can help you . Bye .
Jul 14, 2009 | SanDisk 8GB microSDHC Memory Card with...
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
Formatting micro sd card
i'll make a try:
i) remeber u must have kept any password to micro sd card when the card was in samsung mobile g600 and keeping password to the micro sd card will prevent it from using in other device or even in other mobile phone
ii) so you have remove the password of micro sd card by keeping the card in tsamsung mobile g600 and use the option remove password(the way u kept password or by clicking 'option' when u highlight ur memory card)
Thanking you
M. Sridhar
Dec 31, 2008 | Electronics - Others
SanDisk 2GB microSD Memory Card Logo
877 people viewed this question
Top SanDisk Electronics - Others Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
