Question about Samsung DVD-V4600 DVD Player/VCR
The player is not recognising the disc..when inserting it ejects
Whenver I insert a CD/DVD..it is not recognising and it is ejecting within a minute..
  • 899 Answers
The lasers's lens is to dirty, and the unit will need to be taken apart and the lens will need to be manually cleaned , also it would be a good time to relubricate the gears and door sliding mech's
Posted on Dec 09, 2008
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
DVD player wont eject dicks or play just say's disc error
You need to insert dicks into the DVD player, also, once it ejects the dicks, you should wait 20 minutes or so before attempting to eject more dicks.
Jun 26, 2012 | Televison & Video
DVD NOT RECEIVING DVD DISCS
Hello
The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Mar 02, 2012 | Jamo DMR 60 DVD Player/Receiver
CD stuck in DVD player in tv
I'm sorry that the disc tray is not ejecting. Please check whether you're able to locate a small hole under the tray opening area. If one available, please insert a pin and it will eject manually now..
Dec 18, 2011 | Televison & Video
Opens and closes repeatedly
hello,
The most common reason for the player opening and closing itself is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your player, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your player including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your player going again!
Hope this helps...
Jun 01, 2010 | Apex Digital AD-1125 DVD Player
DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Apr 03, 2009 | Sony BDP-S300 Blu-Ray Disc Player
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
In regards to using the dvd function I am currently inserting a DVD disc and the machine is failing to recognise that a disc is loaded and ejects the disc. However if I load a CD it recognises this and...
YOUR DVD PLAYER HAS THE PROBLEM WITH THE LENS INSIDE THE UNIT. THE ONE WHO READ THE CD'S. YOU HAVE TO ADJUST THE TWO SMALL ADJUSTMENT AT THE BACK OF THE LENS OR IN THE SIDE OF IT. AFTER ADJUSTMENT, IF THE PROBLEM STILL THERE, THEN YOU HAVE TO REPLACE A NEW LENS. KIMTECH....e.bacaro@yahoo.com
Mar 16, 2008 | Televison & Video
Samsung DVD-V4600 DVD Player/VCR Logo
87 people viewed this question
cce772000
Level 1 Expert
