Question about Sony Playstation 3 (PS3) Console
Audio Distortion/fuzzy Distorted sound when playing music off ps3 harddrive, cd's and dvd's. This happens through HDMI to a 1080p tv, and also happens through AV to receiver connected to $1700 speakers. Only started doing this today and my ps3 is a year old. Have tried disconnecting cables and reconnecting, and tried changing any audio settings, both no change.
I restored the default settings on the PS3 and the problem has gone, i don't know what caused it in the first place but i did change some plugs around when moving my TV while PS3 was plugged in so maybe that caused it. Is a mystery to me but fixed now so that is the main thing.
Posted on Dec 10, 2008
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Color distortion when playing DVDs
If the player has other outputs try connecting the player to the tv using one of them, ie: use the A/V output instead of HDMI from the player. If the problem goes away there is something wrong with the input on the tv.
Mar 16, 2008 | Televison & Video
Crackling sound on PS3
the laser is starting to wear out. it cant reda the audio fast enuf to keep up with the visual side of the game resulting in crackling momentary hissing or cutting out of music
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
I have a 37 inch 1080p lg tv which i have just connected to a ht503ph via the hdmi cable. when i am watching the dvd it starts to flicker then the screen goes all white an fuzzy (like the tuning on an old...
Hi elcrozier.Try changing the resolution from 1080p to 1080i in the system setting on the ht503ph. I had the same problem and that fixed it. good luck
Dec 21, 2008 | Audio Players & Recorders
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
Playstation 3 Flickers when set to 1080P
It sucks to see ALLLLLLL these solutions, when I have the solution. Turn off DEEP COLOR in the video settings. It will immediately stop. If it doesn't, then you don't have the typical snow/flickering problem.
Oct 02, 2008 | Sony Playstation 3 (PS3) Console
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Dec 17, 2007 | Onkyo TX-SR500 Receiver
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
244 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
