Picture has lines going top to bottom thru the picture
  • 53 Answers
You will find your answer here
http://www.printertechs.com/tech/print-defects/vertblack.php
Good Luck
Posted on Dec 09, 2008
  • Emma J
    Emma J Mar 11, 2009
    Remember to rate this solution.
    Thanks
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
Changed fuel line on my troy-bilt gas trimmer wichone goes where
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Apr 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
SONY TV PICTURE WENT BLANK WITH A STRAIGHT LINE THRU IT
want to know wat straight line. 1.white line in the middle from left to right or 2.white line from bottom to top there is a big diffrence in these two lines if 1 then u have to check the cvertical section ,the o/put may gone bad if 2 then u have to check the scanning coil
Jan 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Hitachi 50DX10B 2001 model it has lines rolling from top to bottom and appear lighter than the actual picture this problem comes and goes
A photo may tell what the problem is---do you have the same trouble with a DVD etc playing? Faint lines moving bottom to top could be a bad cable lead with a poor ground(shield) If it never does it with a DVD thru one of the rear inputs--suspect a problem with a cable wire connected to the set.
Aug 07, 2009 | Hitachi 50UX58B 50" Rear Projection...
Phillips plasma. red horizonal lines running thru picture
Nancy and Guest. This is caused by an overload in the Y main and buffers. If you are electronically inclined and want to fix this yourself its not hard, but it is a little pricey. There are actually two problems manifested here, the sparkles are from the y main and the lines are from the buffers trying to compensate. If you're up for the daunting task of fixing this yourself, http://www.fixya.com/support/t1625867-phillips_42
This should get you started. Don't hesitate to emial directly for further help. Cfoley@hawaii.rr.com
May 07, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Water leaking from inside door
the water line for the water disp runs in a chase that goes up thru the bottom hinge of the refrig door. SO DONT PULL YOUR DOOR APART! you can order a new water line thru frigidaire and replace the part by removing the water dispenser housing on the door and pulling the line thru the door then inst the new line in reverse. if it looks like too big a job then get a reputable company to inst it for you.
Jan 21, 2009 | Frigidaire GLRT188WD Top Freezer...
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Trouble with pic
Do you have any picture? If so do you lack part of it or the lines go thru a solid picture undisturbed?
Sep 13, 2007 | Sony KV-27S35 27" TV
Line going thru the tv
Josh, When you say a line going through your TV is it a line from left to right or top to bottom? Is there a picture present and this is a line imposed on the picture or just a line by itself? Let me guess, you have no picture just a horizontal line (from left to right) across the middle of the screen. If so that is collapse of the vertical deflection and most likely caused by failure of the vertical IC and possibly linked to some bad caps in theat circuit as well. It's not an expensive repair, just find a good reputable shop. You might also mention, or if they ask, that your unit is a lighbox. Meaning that when they go to repair it the insides of the unit separate from the cabinet for easier access.. Good Luck Bill
Jun 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
60" Ultravision picture problems
HMMMM Dual pictures This is a problem that every projection TV runs into at least once or twice in its lifetime. Its the old convergence IC falure thingy. These IC's go bad and should be replace all at once. These are not consumer replaceable unless you have had training in the electronics or TV repair fields. Please call out a pro to assist you with this repair as A TV is not the place to experiment in because of the HI voltage and saftey issues. Good Luck
Jul 29, 2006 | Hitachi 50DX01B 50" Rear Projection...
44 people viewed this question
k24674
jasbo
jasbo
