Question about Goodman GMS90703BXA Heater
Goodman Furnace GMP 050-03
I have goodman Furnance Model GMP 050-03 the until was working fine until just the other day. Problem The Unit is Turned on And The First Fan comes on the one with the black Vacume tube The Electonic ignigator comes ons on Gets read hot and redy to fire the gas. (But) no Gas is released. The unit Then Shut the Ingianor offf and the Unti Repeates it Self for Three Times same thing then shuts Down. Every Thing Seem to work prestage to the Gas Release and firing the Heater up I have also Been told there is a Senaor Light Ect that Blinks a Code where is it? Apperciate the Help Limited Budget Like the Reast of ALl of us and Two Disabled people in the House any Correct help would Be apperciated
  • dwkcool May 11, 2010
    look in the lower part of the unit the control board is in there and the light is on there that flashes
  • 1,420 Answers
You need to check for 24 volts across the gas valve as the ignitor glows. If you get it, it is a bad gas valve. If there is no voltage or strange voltage, replace the control board.
Posted on Dec 10, 2008
Mine was a composite problem.
Problem #1 - the ignitor, which to the best of my knowledge was 12 years old, didn't ignite anymore (wouldn't get hot).
I replaced that and then had this problem.
I checked the voltage and after a few tries I saw the voltage go up to about 25V for about half a second.
I ended up disconnecting the gas valve terminals and reconnecting a few times, and that seems to have made the trick - bad contacts after 12 years of service.
All in all I paid $60 for the igniter (the new nitride kind) from a local repair person (paid a little extra and avoided waiting for it to be shipped).
I definitely learned a little bit about these things!
Posted on Jan 19, 2009
I had a similar problem and it turned out to be the flame sensor. if you look in the furnace, there are two burn tubes - one has the ignitor and the other will have the flame sensor - it looks like a little rod with a wire coming out of the top end. i readjusted the position of the sensor and turned the air/fuel mixture on the burn tube to burn more fuel than air. it seemed to solve the problem.
Posted on Jan 08, 2009
I Have a beige goodman furnace (old ones) gmp... i replaced the circuit board..it worked fine..then once it reached its desire temprature from thermostat.. fire goes out then 2 min following is the...
Check the pleum high limit switch. Jump this control out and see if the furance runs until the call for heat is satified. Do mot leave the high limit jumperd.
Jan 26, 2011 | Goodman CACF048B2A Air Conditioner
I can't find any info on my Goodman furnace.It's a GMP and the model number on the front of it doesn't match any goodman model numbers G2FD036S17A......I'm lost
Take the top panel off and on the inside of the left side of furnace as you are facing it should have a nameplate rating.
The nameplate rating should have the model number and serial number of the actual unit that you have.
It will list BTUS/Electrical Amps.
Feb 15, 2010 | Heating & Cooling
I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Gas furnance won't stay lit.
have a furnace man take a look it sounds like the itermitter control
Feb 05, 2009 | Goodman GMS80904BNA Open Flame Mid-Size...
Furnance will not come on
No Blink? no call for heat. Check thermostat. Jump out thermostat. Check the fuse in the cabinet as well as in the breaker box. Do you have an emergency switch that may have been turned off? Make sure the door interlock switch is closed and working.
Jan 29, 2009 | Goodman GMS90703BXA Heater
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
553 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
