I have an HDTV flat screen. Suddenly a "shadow" has appeared on the screen. Nothing has hit or damaged the screen. What could this be.
Projection TV correct? This may take some work but it is common for a spec of dust to settle onto the Mirror inside the TV, The back side of the TV screen or onto the Lens from which the Video image is projected. Some TVs have ports that allow you to access the inside of the TV from the side, others you must remove the screen.
This is not something to do every day or every week and it will not improve the picture. You only do this when you notice that it is dirty. Any more than that and you yourself will create a bigger problem. ONLY LIGHTLY DUST the screen. Soaps, water and windex will leave streaks, damage the screen and cause more trouble.
Projection TVs are the eqivalent of a big flashlight showing onto a wall. Put you hand in front of the light and you get a shadow.
Inside you TV there is a light (the TV picture) that bonces of a mirror attached to the inside of the back of the TV. The light reflects off the mirror onto the back of the screen. You view this refelected image from the front. Spiders commonly make webs inside the TV that appear in the picture. Dust Bunnies may get blown into an area and become stuck in the way. Sometimes a lite tap, shake or blow may remove this also.
The screen has an echo image of the actors face, What can i do to fix this?
shadow looks like a splot of liquid but nothing has been put on screen appeared a few months ago can't figure how or what can be done to get rid of it.
