Question about IBM ThinkPad R40 2722 Notebook
Cd door will not stay shut
I have a Dell Computer running XP. Recently my CD door will not stay shut, it will close and pop right back open, the only time it stays closed is when I turn the computer off and push the door in, as soon as I turn the computer on the door pops back out
    President:
  • 2,110 Answers
There might be some problem in ur CD rom motor that control the tray eject,,so u have to take it to nearest service center..
Posted on Dec 09, 2008
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Dell xps 400 dvd/cd drive door won't eject or
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Jan 26, 2012 | Dell Computers & Internet
The cd door on my dell computer model #: IN1910N keeps poping open. everytime i turn on computer it opens. then i close it and wont stop poping open
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
dont forget to vote
Feb 25, 2011 | Dell Computers & Internet
CD/DVD tray will not stay closed
If you push the tray closed and it simply springs back out, then the internal latch is either jambed open or broken off. Open a paperclip and push an end into the black hole you see on the door bezel. push gently in the hole, you feel the clip contact the release mechanism. You may have to push on it several times to see if it can be dislodged (if it's not broken), if the door is still popping open, you may have to change out your drive.
Oct 06, 2009 | Dell Latitude D600 Notebook
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
The door will not open and eject the cd. the amber light stays on all the time
Try going to "my computer" and right click on the icon that shows your cd drive. Then select eject to see if the cd will eject.
If it does not, then shut down your computer. Look for a small pin hole below your cd tray. Unbend a paper clip and insert it into the hole and press. The cd tray should pop open so you can remove that cd.
If the problem continues then it's time for a new cd drive.
Hank
Jun 29, 2009 | Computers & Internet
Cd tray is stuck in open position on my HP computer
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
May 12, 2009 | HP Computers & Internet
CD player cover/door won't stay closed
The intermittent version of this seems to be related to the cable that goes to the subwoofer portion. Have seen this behavior when the cable got loose. Unfortunately, I believe that this behavior may get worse in the long run and cause CDs to not play at all.
Jan 25, 2008 | Teac CD-X8 CD Shelf System
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
IBM ThinkPad R40 2722 Notebook Logo
128 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
