Question about HP Officejet 5610 All-In-One InkJet Printer
Paperjam error I have paper jam error in HP5610 printer. plz solve my problem.
  • 53 Answers
Jooo error
Hi
Remove the paper that needs to be printed, close all doors. If it cannot solve the problem remove the paperjam and restart the machine.
Feb 23, 2014 | Office Equipment & Supplies
Error paper jam
It is possible that there is a little peice of paper that has ripped off of the sheet that was jammed. Was the sheet whole when you removed it? If not, check the location where the paper was jammed for bits of the last sheet of paper.
Sep 17, 2013 | HiTi P510L Photo Printer
Hp laserjet 3015 paperjam
Plz see if the corner of the paper will be folded or it has been folded earlier and now it is straight then also that paper will be jammed. So use new unfoiled paper.
While inserting it see it is straight in the tray.
Oct 26, 2012 | HP LaserJet 3015 All-In-One Printer
Canon pixma MP240: keeps flashing Error E3 paperjam but not paper can be seen inside the printer. Makes noises as though priniting but only puts blank pages through. If power is turned off and...
Hello thanks for using fixya
E3 error is mostly because of paper jam
. their may be small bit paper jam in side.
Even it feels that their is no any piece of paper inside the printer but actually it exist & inside of the printer makes paper sensor & its not function properly
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Paperjam in a hp photosmart c6380 all in one , how do I open to clear out paperjam ?
I could provide you with written instructions to clear paper jam, however i thought it would be good to provide you with a link to solve it for better understanding.
Click on the link below and it will give you step by step instructions to clear a paper jam with video demonstration.
Clear Paper Jam
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | HP Photosmart C6380 All-In-One InkJet...
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Paperjam tray 1 error code 201.52
If you remove tray 1, is there a jam? When the printer is starting to print, does it sound like it is trying to pick up paper from the tray a few times, and then changes to the jam error? If so, then the pickup rollers are worn. You can confirm this by removing tray 1 and feeling the rollers which are located in the top of the tray in the front. If they feel smooth, then they need to be replaced.
Feb 22, 2009 | IBM Infoprint 1572n Laser Printer
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
