Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Engine Problems My snowmobile wont start and i cant get it to go no mater how long i pull on it. i think i need some starter fluid or gas to put down the carberator to make it go what should i do?
  • 1 more comment
  • Anonymous Dec 11, 2008
    when i pull i get a spark out of the spark plugs. i also poured some gasoline down the carbs and it seemed to help i can get it to start for about 5 seconds then it dies on me. im guessing that one of my gas lines are frozen so i may have to go to the store and get some heat. what do u think is wrong with it. It ran last year really good.
  • Anonymous Jan 17, 2009
    I HAVE SPARK ON THE SPARK PLUG AND I SPRAYEED SOME STARTING FLUID INTO THE CARB BUT I CANNOT SEEM TO GET IT TO FIRE. IT HAS A STARTER AND I TRIED JUMPING IT BUT STILL NO LUCK
  • Mel Jacobson
    Mel Jacobson May 11, 2010
    You'll have to describe what happens when u try and crank it
  • 216 Answers
Sounds like your not getting gas into the carb........ probably a pluged line or filter. Your on the right track
Posted on Dec 14, 2008
98 Yamaha 700 vmax xtc snowmobile has spark getting gas new plugs new battery won't start won't pop tors unplugged won't do anything but turn over
Try spraying a little starter fluid into the air intake. If it tries to start, the carburetor needs adjustment or cleaning and rebuilding or replacing. DO NOT USE A LOT OF STARTER FLUID!
Dec 03, 2017 | Yamaha 2007 VK Professional
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
My skandic 550 will not start thawed it out! Put new battery! Tried pull start it very hard to pull
Will it turn over with the starter, what kind of sound did you hear? It's unusual to have any problems with the 550's how many miles are on it? You thawed it out was it buried and do you have it at room temp or at least above freezing? Options include starter engaged and not releasing, ice around the clutch making it hard to turn over, I doubt there is a motor problem, remove the drive belt and pull it over or remove the spark plugs and roll it over by hand it should free wheel
Jan 28, 2015 | Ski-Doo 2012 Skandic WT 550F
Sears troubleshooting
I think you mean it wont run after running out of gas. You may have to remove the spark plug and shoot a small shot of starting fluid in the hole and replace the plug. Cranking means turning the engine with the starter motor.
Aug 15, 2014 | Garden
1995 pantera engine rolls over but wont'dwith electric startbut starts with pullcord
Make sure th battery is the right one for the machine,Someone probably cheaped out and put the wrong one in.
Mar 08, 2014 | Ski-Doo 2004 Summit Adrenaline 600 H.O
Ran out of gas wont start
Spray Ether (Starting Fluid with Upper Lubrication) into the Air Box and pull, the sled will start and the vacuum will get the gas into the lines. Quick sprays to keep it running as it starts to die, then squirt again..
Mar 30, 2013 | Polaris 2012 Switchback 800 Assault 144
ENGINE WILL NOT START
My power-washer suffers from same problem after sitting idle.
After paying for a new carburetor, I discovered how important it is to drain the gas if washer is going to sit idle.
Another time, we had a problem with the screen covering exhaust outlet. Deposits from the engine + dirt clogged the screen. Although it's not the solution for everybody, we broke the screen open with a screwdriver and the machine ran fine after that.
Small gas engines require 3 things. Compression, spark, and fuel. Take out spark plug. Put finger over spark plug hole and pull cord or push starter. Do you feel suction? If yes, then you have compression.
If machine will not turn over at all, then your motor might have run out of oil. Power washer needs oil in 2 places. It needs oil for the engine just like a lawn mower. Oil plugs are located low on each side of engine. It doesn't hurt to change oil, but do NOT NOT turn small engine upside down or oil will get into carburetor which requires removal and cleaning. I learned that the hard way.
The power washer also needs oil for the pump head. This is the box attached to front of engine. Usually 10W20 non-detergent is a good choice. Oil is usually about half way up inside pump head.
Now hook spark-wire back to spark plug. Hold spark plug in hand. Touch threads of spark plug to metal spark plug opening. Now pull cord or push starter. Do you see sparking in the spark plug gap? If yes, then you have spark. Put new spark plug in anyway. If no, then you need parts from small engine repair service.
Spark plug is in. Take off air filter so you have access to carburetor air intake. Put fresh gas in tank. Use starter spray or WD-40 as a starting accelerant. Set your choke to start engine. Spray starter fluid into carburetor opening and pull cord or push starter. The engine should fire up on the starter fluid. If engine doesn't fire, then try setting choke in different positions. If engine doesn't fire up then carburetor is suspect.
If engine fires but dies, keep spraying starter fluid into carburetor to see if you can keep it going that way ... and then move choke in different positions ... you might need extra hands for that maneuver.
If machine turns on, but dies when filter is put back, then filter might be clogged. Time for a new filter anyway.
Finally check the fuel filter and fuel line below the gas tank. It usually has a hex head bolt. Loosen bolt and see if fuel is able to fall out of tank. Loosen rubber fuel line at both ends and see if fuel is flowing. This will tell you if fuel can get to carburetor.
Usually these measures get the thing going or tell you if professional service is needed.
Sep 29, 2010 | Briggs Stratton 020273 Elite Series...
I think the bulb is blowing air and not fuel...wont start. How do I check for sure?
You could pull the spark plug and put some fuel or starter fluid in the cylinder, replace the spark plug and then try starting it. This will at least tell you if it is a gas issue. Good luck!
Mar 02, 2010 | Craftsman Garden
Hi i have a 2002 gas gas fse 450 replaced starter motor bushes and sprag clutch and battery. and it wont start when i kick the bike over the engine feels tigh is it because the engine has not been started...
it could be your starter cluch draging take it off again and check it out or you will burn out the starter trying to start the engine if all is well there put a fuw drops of engine oil into the pot down the spark plug hole and try kicking the bike over without a plug in it till it frees off
Jan 23, 2010 | 2005 Gas Gas SM 450 FSE
Cant get my snowmobile started
you need to remove the old gas and replace
drain gas line if you can get to the carbs use starting fluid
( remove spark plugs and observe also clean with gas and wire brush
also while you have the plug out put the metal side of the spark plug (where you woud turn with a wrench) and turn over with ignition switch
to make sure u are getting a spark
good luck and happy snow mobileing
Jan 06, 2009 | Sport & Outdoor - Others
Lands Phones Logo
95 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
