Question about IOGear 800 dpi USB Optical Mini Mouse w/Retractable Cable [ GME222A ] (122370)
Won't work with PC
I plugged in the USB receiver. Turned on the mouse. Pressed down the connect buttons. Nothing. It worked with my laptop. Why doesn't it work with the PC. Is it because the tower is ont he floor and not adjacent to the mouse? Is it because I still have the wired mouse operating? It shouldn't because I didn't have to do anything to stop the ball on the laptop. If it doesn't work, what's the point of keeping it.
    Sergeant:
  • 310 Answers
Hi alot of people have problems working out the wireless devices. You need to plug in the USB reciever load windows till desktop appears, hold down the reciever button until it flashs then quickly turn over mouse and press connect button in. and you should see the reciever flicker, and it should start working. if it dont try swapping the batterys as they dont last long... Hope this helps John
Posted on Mar 01, 2007
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
My mouse was just working and all of a sudden it stopped, I changed the batteries, reset the small button on the bottom and also pushed the button on the plug in portion. Help Allen
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still not working. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the battery opening appeared to be bent down away from the contact on the battery tray. So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Dec 08, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
Jul 21, 2009 | AVENUES The SPYDER SwissGear Wireless...
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
I have purchased a Microsoft Wireless Optical Desktop 700 (Keyboard & mouse). I have plugged the wireless receiver in, and get a flashing green light when I press the button on the front. The green...
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Jul 16, 2008 | Computers & Internet
Logitech LX5 Cordless Mouse
Try
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 22, 2007 | Computers & Internet
Re: kensignton wireless mouse, connected but not working
have you checked the battries in the mouse as the battries that com with the mouse don't last long and have you pressed the connect buttons on receiver and mouse as somtimes usb power receivers loose connection on laptops try this one. hope this works
Aug 13, 2007 | Kensington Mouse-In-A-Box Optical Elite...
No Cursor
Did you register the mouse to the receiver? There should be a button on the receiver, the bottom of the mouse or both used to connect the wireless mouse to the receiver. Also, if you do not have a red light on the bottom of your mouse it may have a battery problem.
Jul 22, 2007 | Logitech Optical Mouse Plus Usb Port...
IOGear 800 dpi USB Optical Mini Mouse w/Retractable Cable [ GME222A ] (122370) Logo
87 people viewed this question
Top IOGear Computers & Internet Experts
Damen Wong
Damen Wong
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
