Question about Mitsubishi WS-65807 65" Rear Projection Television
TV Image bending
Any idea why my TV image is bending?
  • ken petri Feb 26, 2007
    The image will work fine and suddenly the image bends and may suddenly go back to normal. So, no, there isn't a magnet suddenly appearing and disappearing. Any other ideas?
I had the same problem with the picture bending on my Mitsubishi WS-65807. The repair man said I had a picture tube going out. Luckily mine was under warranty. Otherwise, he said they run about $300.00 each (there are 3 but only 1 was going).
Posted on Mar 31, 2007
Maybe you have a magnet near it?
Posted on Feb 26, 2007
How do I get my Samsung LED 6450 TV to display image on the screen?
when you disconnect cable from power board to MB, does the backlight stay on, if, so, the Motherboard needs replaced again
Oct 29, 2017 | Samsung Televison & Video
I have a burned in image on my 32" ProScan flat screen tv. How do I get rid of the image?
Can't be done. That's why it's not a good idea to leave an image on a screen for a long time. A lot of computer screens have burned in images.
May 29, 2016 | Proscan Televison & Video
Is there a way to fix(bend it back) a bent A/C line without replacing the A/C lines ?
I can't see the image, but the short answer is no.
The line you are trying to heat up has gas in it that is minus 30 degrees.
You may be able to bend the line an 1/8 inch or so, but not much.
Jul 27, 2012 | Cars & Trucks
Reset to get image
Try a system reset to clear the eeprom. Menu 2470 to get to the service menu, then immediately press enter on the remote. Goodluck.
Jul 05, 2010 | Mitsubishi WD-52526 LCD TV
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
Image has bend at top of screen
first reset the setting to factory default. if it persists on a regular image too, either the lens, the tunnel or something else in the optical engine is damaged (from a fall?).
Jul 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Panasonic 47WX53G Blue color out of convergence
Sounds like the convergence amp ICs bad. They will cause the type of problem and distortion youre describing.
Jan 20, 2008 | Sony KP-51WS500 51" Rear Projection...
2004 Phillis 47 " flat panel ghost image
Yes, it called ghost image. You can try to go in the service menu, and scroll to ghost image. Turn tv off, wait till red light stops blinking, and then on the remote press the input button. at the same time press the power button on the tv. this should put you in the service mode. If nervous about this call tech assist at Hittachi.
Nov 25, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Image is totally distorted
Did you also replace the bias resistors required when you converted from STK392-110 to the higher STK392-xxx modules? If I wer you I would go back to the orginal modules only new ones. Then I would also get a schematic to test the voltage levels on the chips to make sure they are the same as on the schematic.
Jul 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
227 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
