C drive formating
I dont have access to my c drive because of suspected corrupted master boot record... i dont no to use fdisk command from windows 98 cd!!!! Can you help me please.... *VINCE* THANKS!!!
  • HW_Dude
    HW_Dude May 11, 2010
    Was your installation a Windows 98 installation ?
    If not, what operation system was installed ?
    Scholar:
  • 122 Answers
The basic fdisk command to repair the mbr is fdisk /mbr. that will replace the mbr but you may have to re-partion reformat and install from scratch. Good Luck
Posted on Jul 29, 2009
It's impossible install MBR, How I can get install?
If this MBR mean, Master Boot Record, it's a DOS-alike thing.
You require a DOS or Windows 95 / 98 bootflop, containing the program FDISK (forgot if it was .com or .exe)
After booting you get the DOS-prompt which is text-based and looks like :
"A:>_" or "C:>_"
Now, in this case you enter the following: "fdisk /mbr"
So the DOS-prompt will look like :
"A:>fdisk /mbr" or "C:>fdisk /mbr"
Then you hit the ENTER-button at your keyboard and if DOS can find this fdisk-program, it will rewrite the master boot record of your harddisk.
Oct 11, 2013 | Toshiba Computers & Internet
How to format hard drive with windwos 98
You need a bootable disk that have DOS o/s inside it. boot from the disk and type these commands:
FDISK to create partition
FORMAT to format a drive (for example: 'A:>FORMAT C:')
(Usually the windows 98 setup CD already provide this)
otherwise, you may prefer to try 'smart fdisk' or other softwares that allow you to manage your disk with better GUI (Graphivcal User Interface). try to look for it.
Oct 04, 2011 | Microsoft Windows 98 for PC
Corrupt missing C:\windows\system32\config\system no original windows xp oem disk cannot use recovery console cannot get to a c:/ prompt no floppies have cd rom bios does not support usb boot possiblity...
Your master boot record of the hard disk is damaged. I suppose you have access to CDROM through bios. But it is not clear from your question. Set CDROM as first boot device. Get a bootable CD & make sure that it contains fdisk utility. Boot from it & you will get a:\ prompt. at a:\prompt type fdisk/mbr & press enter. Your master boot record of hard disk will replace. Now you will be able to go to c:\ prompt. Use your your xp cd to recover your windows.
-sonsunny
Jul 14, 2011 | Dell Dimension 8250 PC Desktop
How do i blow away my hard drive.
If you want to erase without any possibility of anyone accessing the data, you need a 'wipe' program. If you just want to start over, then you can use the "fdisk" and "format" command.
FDISK chops the disk into 'partitions' [divides into C,D,E,F etc disks], and writes the MBR, or master boot record, and system files to enable booting the hard drive. Format is used to create a 'file system', such as FAT or NTFS on a hard drive.
tom
Aug 11, 2010 | Gateway Computers & Internet
Soyo sy-p4vgm motherboard unable to access BIOS setup menu
Offcourse! first of all insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
2nd way, If everything could not be possible then you should boot from CD again then select your CD drive and type a command fdisk and press y or enter 2 times. Now you choose 4 number and press enter and check the drive format if it is not FAT32 its mean that you should press 3 and then press 4 and now press enter then press escape. Then press three button at a time Ctrl+Alt+Del now your system will reboot now once again Boot from CD and choose CD drive and type fdisk and choose 1 then choose1 and now press enter and once again press three button at a time Ctrl+Alt+Del now your system will reboot. Once again boot from CD and select your CD drive and now you can install windows 98 now insert CD into CD ROM then boot from cd. Select your CD drive like d: or e: or f: etc and then press enter. Now give a commond format c:/u/v and press enter. After the formating drive you can install windows 98 so now reboot your system again. Then boot from CD once again and choose your drive and install windows.
Thank You
Jul 30, 2009 | Soyo SY-P4VGM Motherboard
Disk read error occured
If not give it a go and do a repair if needed again!
1- You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
2 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
3- or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!!
Mar 26, 2009 | Dell Inspiron 1525 Laptop Jet Black
Presario cq60 104tu
The master boot record maybe be corrupted or virus infected.
To fix the MBR, boot up with your DOS disk and type fdisk /mbr
Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
Feb 27, 2009 | Compaq Computers & Internet
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Want to format c drive from window 98 cd using dos?
boot pc in command prompt.....and type format c: /f
Dec 09, 2008 | Computers & Internet
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
Computers & Internet Logo
David Payne
David Payne
