Question about Compaq Presario C700T Notebook
Address of laptop repairing center
Some time when i press start switch of my laptop ,it is found that there is no sign of booting.........i want a complete check of my laptop system,please help.
  • Compaq Master
  • 13,433 Answers
My dell m90 will not start up.It goes through the starting windows routine and then goes to a black screen?
when you start up your computer press f8 a menu will come up select Last know configuration that worked press enter.see if that works.If not press f8 again and select safe mode press enter see if it will boot to safe mode.if it boots go to my computer right click your boot drive select double click tools then click check now button a menu will come up tick automatic repair then start repair.It will ask you to shedule a repair click ok when you restart it will check and repair your hard drive.If this does not work you can put your operating system disk in your drive and boot to it and click repair and follow the on screen instructions
Oct 26, 2012 | Dell Precision M90 Notebook
Driver not found reboot your system and run this setup again
Kenlaya, This will be a bit more complex but i hope you will grasp.
That is a sign of a corrupt system file that makes the operating system unstable and fail to boot up.
If you are using Windows 7,
Put the CD in the CD drive and restart your computer. When you are prompted, choose System repair, or start-up repair. This will fix your problem. Note: The Serious the problem, the longer it will take to fix it up.
If your laptop is running Windows XP....
Put the Operating system CD (e.g XP, Win 7 or Vista or anything like that), in the CD drive. Boot your laptop while pressing F2 and this will let you go to the system BIOS for your laptop. In the system BIOS locate the boot order or the boot sequence and configure the CD drive to be the first in the boot order and restart your laptop. This will let the computer boot from the CD.
Wait until the CD finishes loading its files, then you are going to be prompted to press Enter (to continue) or press 'R" to repair using an automated repair.
At this point just press enter and continue, then you will press F8 for license agreement and then you will be prompted again to press Esc if you want to install your Operating system afresh, or to press "R" to repair your OS(Operating system) or press F3 to quit. At this point, you can now press R to repair. Sit back and relax while the CD replaces old with new files in your Windows directory....
When it is done, it will restart and continue in another face where you will be prompted to answer a few question and then your operating system would have been cleansed.
Aug 18, 2011 | Lenovo Computers & Internet
I have a sony PCG-6N2L..when I turn on the computer, the logo screen comes up then the windows xp sreen...it doesn't ever bring up my sign on screen it keeps repeating the logo screen and the windows xp...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Apr 11, 2011 | Sony VAIO GRZ660 Notebook
I hv acer travel mate 5520 recently installed XP sp3 in my laptop then i found a prob when my laptop start an it came to window sign at start then my pc stop working or not start the window after 5 or 7...
go to run and type "msconfig"(without inverted commas)
go to startup tab and uncheck the softwares you don't require. this will certainly help.
Oct 31, 2009 | Computers & Internet
Difficult to boot. I must try 5-10 times or press the mainboard.
When rebooting or shutting down, hold the power button for at least five seconds.
Aug 31, 2009 | HP Compaq nx8220 Notebook
Laptop opening
OK try this
  1. Go into your bios usualy by presing F2 or Delete while booting, reset to fabrick defaults.
  2. Its also possible that your computer is looking for a other boot device CD/LAN/ USB etc. that can also be changed in your bios.
  3. A faulty hard drive or bad IDE connection is also possible.
Thank you
Dec 13, 2008 | Compaq Presario C700T Notebook
Laptop opening
hi,
in compaq the power-on switch is not sensitive enough to kick start on a single touch.what you need to do is press button firmly.but still if you face the same problem,you have to the notebook to HP Total care to check the switch .probably this cannot be a serious issue even though it is a bit irritating one.
Dec 09, 2008 | Compaq Presario C700T Notebook
Hello
go into your bios setup utility program and change boot settings there.. enable fast boot, and switch the first boot device to your hard drive..
Jun 07, 2008 | BenQ Joybook 5100U Notebook
GATEWAY LAPTOP ML227B
Most likely your windows installation is corrupt or your harddrive is damaged. I would recommend takeing the laptop to a local pc repair shop / center for analysis. Shouldnt cost much. And it will save both of you alot of time and energy.
I asume the laptop is constantly in that loop.. you put power on that thing comes up, it tryes to load but fails, it starts up again and the same text come up blaablaa. Then thats probably the problem.
Feb 10, 2008 | Compaq NX6110 TFT XGA Notebook
Compaq Presario C700T Notebook Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
