Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
Samsung Omnia - Main Menu Function key gives a shortcut error.
I bought the phone about 10 days ago. Everything was working great. Then one day when I used the main menu shortcut key (top right rear side), the screen froze and I have not been able to use this function key anymore. An error message pops up on the screen which reads "Shortcut Target - Error opening shortcut or locating the target filename".
How do I fix this? Help I'm desparate!
  • 1 more comment
  • Phatnat Jan 05, 2009
    Main Menu Function key gives a shortcut error after only one day of working normally without changing any settings. When you go to the buttons menu and re-set this function, it makes no change.
  • Anonymous Jan 30, 2009
    I have the same problem on my Omnia, also happened only a few days after getting it. Can't find a solution, tried updating firmware but it's already the newest version
  • Anonymous Feb 23, 2009
    hi!
    i am from croatia and have the same problem, my omnia doesn't reacts at buttons. i press any button and nothing happens! but touch screen works! i tried to reset but nothing, can anyone help me? thanks
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Posted on May 11, 2009
I have an Omnia 2 phone and cannot use the shortcut widget anymore.
Posted on Jun 28, 2010
Itapon nyo nlng mga fown nyo haha,...
Posted on May 15, 2009
Mouse buttons left right switching sticky keys
Remember you can always use the keypad in place of the mouse. Try replacing the mouse with another one. If that doesn't work, it is probably something in the software. Do a scan on the system next.
Jan 31, 2013 | Microsoft Computers & Internet
Problm with my omnia!!-- brightnes problm!
Ah .. don worry . It jus de prob wit samsung s/w .. Jus show tat prob to de samsung care in yo city directly .
Feb 28, 2010 | Samsung Omnia Pro B7320 Smartphone
It there a manual for the Omnia SGH-i900 and if so where can I download it.
Check this link:
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/OMNIA%20SGH-I900-_D
Have a great day!
Jun 12, 2009 | Samsung Cell Phones
Main menu screen problem
I think the degitizer (touch screen ) is faulty.
Replace it.
May 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My camera shortcut
I had the same problem with my Omnia right out of the box. I fixed it by changing what the button does and saving it. Then I changed it back to Camera and it started working!
Apr 02, 2009 | Samsung Omnia Cell Phone
Cant pick up a network, it keeps searching
If it is continueing to search for a network. Wanna make sure you have the correct simcard for the carrier in your phone. And it is in the phone correctly. Maybe the phone is NOT completely unlocked. If that all works, check your network in the phone.
  1. At the main screen, press the Menu key.
  2. Scroll to and select Settings.
  3. Scroll to and select Network.
  4. Scroll to and select Network Setup.
  5. Scroll to Type and select Change.
  6. Scroll to and select AUTOMATIC
SAVE. Besure once a day to power down the for about 10-20 seconds a day.
Feb 14, 2009 | Motorola Mobility RAZR V3x Cellular Phone
BLUTOOTH DATA
main menu - shortcuts - file explorer. They will be there but not assigned to a program so the omnia doesnt know what to do with it. I havent worked out hoe to assign a program to these files yet but will keep you posted
Jan 02, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My Samsung Omnia keeps shutting off on its own
Before you go and try and update the software on the phone it is always best to try the easiest soloution first.
The problem may just simply be a power management problem so try this.
1. On the main screen at the bottom task bar you should see phone on the left and main menu on the right. Now click main menu.
2. Now click settings
3. Now you see 3 tabs at the bottom. Personal, System and connections. Press the system tab.
4. On the new screen scroll down to the bottom and you should see power with a battery icon. Click it.
5. Now on this screen you see another 3 tabs at the bottom (there are actual 7 which are obtain through scroll), battery, battery power and external power. Click battery power.
6. On this screen you will see that it can be set to turn of if not used after so many minutes so changing these settings may solve your problem.
I hope this is useful??
Jan 01, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
I bought a Samsung Omnia about two months ago and have hardly used it but for about two weeks now it just keeps shutting off on it's own even when the battery is fully charged. Sometimes it goes off as...
you need to hard reset it. it will be like factory setting. follow below procedure to hard reset. you will loose personal data on phone memory like contacts,sms,settings, etc.
  1. Press reset pin button ONCE (do not hold)
  2. Once you see the Samsung Omnia appears on the screen, immediately press the SEND and END key simultaneously
  3. Then the screen appears asking you whether you are sure to format
  4. Press SEND to format or END to cancel
Jan 01, 2009 | Cell Phones
Accelarometer issues for samsung omnia...not working whatsoever
Hi, I had the same problem and the solution was very simple. You have to go to Menu\Settings\PowerBattery power and to set at On Battery Power "None". Please let me know if it is working (lugoj4u@yahoo.com).
Dec 20, 2008 | Samsung Lands Phones
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
1,426 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
