Question about Dell Vostro 1500 Notebook
Monitor no longer working after latop connection
My PC and monitor were working fine originally.
But then I connected the laptop to the monitor and pressed the Function>CRT/LCD buttton and it worked well.
When I recconencted by pc to the monitor, the monitor now says no Signal. Can anyone help.
  • 53 Answers
Assuming that you are using Windows Vista, and the monitor is plugged in and connected correctly (with power on!), right click on your desktop, and select Personalise, and then Display Settings. You will see the second monitor greyed out. Right click on the greyed out monitor and select "Attached". Click Apply. The monitor should now be activated.
Sometimes, there are specific graphics card programs loaded on laptops, such as NVIDIA etc.. which may also control the settings.
Posted on Dec 09, 2008
PC SWITCHS ON BUT NO PICTURE
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
Sep 27, 2011 | Mesh Matrix 6000+ DX PC Desktop
My pc does not give display ? Why
Time Required: Testing a monitor could take from a few minutes to much longer depending on the cause of the problem Here's How:
  2. Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable. Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.
  3. Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.
  4. Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.
  5. Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.
    • If the new monitor you connected does not show anything either, proceed to Step 6.
    • If the new monitor you connected does show information from your computer, proceed to Step 7.
  6. Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.
  7. Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.
    Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8.
  8. Replace the monitor.
    WARNING: A computer monitor is not a user serviceable device. In other words - do not open the monitor and attempt to repair it yourself. If you would rather have your dead monitor serviced instead of replaced then please let a professional do it.
Aug 02, 2010 | Dell Dimension 2400 PC Desktop
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
Compaq presario 700 monitor off
Hi
Maybe, depending on the problem. Laptop monitor problems fall into three categories. 1. Screen electronics or lamp. 2. Inverter. 3. Laptop video chip. I've been repairing latops ever since they arrived on the market. First connect an external monitor to the laptop - this will show you whether or not the laptop motherboard is working correctly. If it is then you'll need to replace either the screen or the inverter. So as not to waste alot of money, at this point I would suugest going to a reputable repair person or check my website www.micromendllc.com
Jun 05, 2010 | Compaq Presario 700 470024-192 Notebook
Hp w1907 monitor does not detect any input and goes into sleep mode. checked wiring and connections -- looks normal. No trouble until today.
try to connect the monitor to another working PC, or to a laptop monitor socket, if it works there... then there is a prblem on you PC display driver or display card inside your PC, try to connect another working monitor to you trouble PC and check if that works.
Dec 07, 2009 | HP w1907 LCD Monitor
Connecting latop to tv?
use s-video cable  a little round plug most newer tvs have s-video imput that is standard resulution
May 22, 2009 | Dell Inspiron 2200 Notebook
Monitor flickers on and off occassionally
it sound to be loosen connection from inside the latop..you must check the lcd cable and refix it tightly..try..i hve same problem that i fixed
Jan 04, 2009 | Gateway M320X Notebook
I am trying to connect an external monitor to my legacy PowerBook G4 laptop.  I have the original video adapter dongle that Apple provided, which goes from digital video to VGA.  I've tried different...
Since your laptop's display has a problem, that could indicate trouble elsewhere in the computer that is preventing you from adjusting your resolution properly. In fact, a shrunken display points more to a problem in the video processing, not in the display itself.
Dec 27, 2008 | Computers & Internet
HP Laptop Battery problem
there is some circuit loosing inside the laptop's battery connection. it need to oprate technically.
Nov 08, 2008 | Computers & Internet
Toshiba tecra 8100 no display
this problem occurs in the video chipset,because when you hook up the external vga there is no display right?
if you hook up the vga into the monitor it would come display if the problem only with inverter or lcd.
Jul 07, 2008 | Toshiba Tecra M2 Notebook
Dell Vostro 1500 Notebook Logo
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
