Question about Compaq Presario 700 470024-192 Notebook
Laptop opening some time when i press start switch of my compaq laptop it is found that there is no sign of booting....problem is found very often...i want a entire checking of my system......please help..
    Novelist:
    Scholar:
  • 50 Answers
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
a39
Posted on Dec 25, 2008
Boot image did not authenticate
My laptop compaq CQ58 does not start up so it gives me this message selected boot image did not Authenticate. Press <Enter> to continue. If l press continue it switches off, Pliz help wat should l do
Dec 02, 2012 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
I have compaq pc presario c300 i cant open windows meaning when i start up my laptop the xp window is just come n go faster (popUp)
When you boot up press F8 function key and Windows will give a list of boot options, select Last Known Good Configuration and hopefully Windows will start up correctly. If not boot up again, press F8 and select Safe Mode and Windows should boot up in standard VGA display mode.
If this doesn't work you need the Compac restore CD disk that came with your laptop. Boot up with this CD to restore your laptop, you most likely will lose data.
Jul 29, 2009 | HP Compaq Presario C304NR Notebook
I inherited N600C which had protected password
remove it again and make sure it inserted/seated correctly..
press power button to boot if nothing happens wait a minute or so and press and hold power button til unit turns off (you will hear this)
then reboot.
Jan 27, 2009 | HP Compaq Evo Notebook N600c
DVD drive keeps on opening when starting
If the boot priority in the BIOS setup screen is set to thr CD it  will open the cd door every time you boot looking for the BOOT cd.    It will not accept anything else, at that point except a boot cd since it hasn't found the operating system (windows) yet.    By "blue laptop" you mean "blue screen" DO a "Windows restore" or reinstall windows from the reinstall cd or Harddrive partision containing the restore files.
Jan 27, 2009 | HP Compaq Presario V2000 Notebook
Laptop opening
OK try this
  1. Go into your bios usualy by presing F2 or Delete while booting, reset to fabrick defaults.
  2. Its also possible that your computer is looking for a other boot device CD/LAN/ USB etc. that can also be changed in your bios.
  3. A faulty hard drive or bad IDE connection is also possible.
Thank you
Dec 13, 2008 | Compaq Presario C700T Notebook
Laptop opening
hi,
in compaq the power-on switch is not sensitive enough to kick start on a single touch.what you need to do is press button firmly.but still if you face the same problem,you have to the notebook to HP Total care to check the switch .probably this cannot be a serious issue even though it is a bit irritating one.
Dec 09, 2008 | Compaq Presario C700T Notebook
Compaq presario laptop blinking power button
REMOVED BATTERY AND CHECK ONLY IN AC MODE
IF ITS START PRESS F8 AFTER BOOTING AND OPEN IN SAFE MODE
Jun 21, 2008 | Compaq Presario Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
