Question about Brother LS-2125 Mechanical Sewing Machine
My fabric won't advance.
The material won't advance. I believe it is the feed dogs. Can I fix this myself? The machine runs great, but the dogs will not come up high enough to pull the fabric. We have dismantled the machinge twice and connot figure out why the feed dogs do not grab the material. Please help!! :(
  • 5 more comments
  • rhenken Dec 08, 2008
    I can not find the lever to raise the feed dog where would it be. I can see two screws that I tried to tighten but that didn't help. Where is the lever
  • buckswoman Dec 12, 2008
    I cannot find this "lever" I'm done! :O)
  • Anonymous Mar 14, 2014
    Feed dog does not advance fabric.
    The feed dogs on the machine do not feed the fabric through--I have to pull it through
  • Anonymous Mar 29, 2014
    the feed dogs are stuck in the down position and the fabric is not advancing which causes the material to be stuck sewing repeatedly in the same place
  • Anonymous Mar 31, 2014
    Cloth will not feed have to pull it through (thin cotton material) Its like the feed dogs are down
    feed dogs are not feeding the fabric ...stitches are very small..the feed dog are up
    Novelist:
    Scholar:
  • 84 Answers
Hi Jodyk...Remove your flatbed so you can access your bobbin area. Open the cover of the bobbin area. The shiny/bright components consist of the Bobbin, which snaps into the Shuttle Hook, which is contained in the Race. Immediately right of the Race is a pewter/matte silver colored lever. Press the lower portion of the lever to raise the Feed Dogs. Pressing the upper portion drops the Feed Dogs, and is commonly used to accomplish free-hand applique work......good luck my friend.
Posted on Aug 02, 2007
  • layla25953 Sep 17, 2011
    great instructions found the lever never fixed a sewing machine or sew. But I can read instructions Thank you my daughter is thrilled and I am a grandmother. I can fix anything like my daddy always said read the instructions!!
  • Martha Willis
    Martha Willis Oct 25, 2011
    That was the quickest fix ever. The lever must have been bumped during a bobbin change or something. Yeah! I win! Thank you
Posted on Dec 08, 2008
I found it worked right away many thanks! from joyce cantell, bath maine
Posted on Jan 06, 2008
Brother 8015 and the feed dogs don't move the material forward. The feed dogs go up and down though. How do I get it to work correctly?
Check that the stitch length is set at #2 or higher so the feed dogs will actually advance the fabric. Verify that the feed dogs have not been dropped, as for darning.
Apr 19, 2017 | Brother Sewing Machines
I have a new home excel 23lL sewing machine and the fabric won't advance
check the position of the forward/ reverse setting
near the middle will not advance the material
take it in for a service
Oct 25, 2016 | New Home Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
THE FEED DOG ON MY EUROPROX 473B IS NOT MOVING FRONT TO BACK SO IT IS NOT FEEDING MATERIAL THROUGH WHAT COULD BE THE CAUSE?
Check that the feed dogs are in the "up" position for sewing (not dropped for darning). Also, verify that the stitch length is set to around #2 or 2.5. This will move the fabric well enough that it will actually advance with the feed dogs. If the stitch length is too short, the fabric will not advance sufficiently and will cause the needle to stitch in place.
If this does not cure the problem, you should take it for service.
May 12, 2016 | Sewing Machines
I only have a small amount of feed through the sewing claw, i mostly have to pull it through on my Toyota 2400, is this normal is is something wrong?
Unable to locate much information about your make/model machine.
If your machine has the capability of dropping the feed dogs for darning or free motion quilting, check that the feed dogs are in the up position for sewing. Also, verify that the stitch length is set to at least #2. Any shorter stitch selection will cause the machine to advance the fabric so slightly that it will nearly sew in place.
Some machines also have a pressure adjustment for the presser foot. If the fabric you are sewing is very fine, the feed dogs may have difficulty gripping the fabric to advance it through the machine. You can add body to the fabric by including a stabilizer when sewing the fabric, ie a wash-away stabilizer.
May 05, 2016 | Toyota Sewing Machines
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
The fabric is not advancing when I sew. What can I do to fix it?
The feed dog are probably dropped lower than the the throat plate. Most machines have a setting for darning that requires that the feed dog to be dropped below the sewing surface. There is a separate knob to change the feed dog from this lowered position so the feed dog, when the balance wheel is rotated will come up above the sewing surface to move the material. Another thing could be that the stitch length lever is set on "0". This is basically telling your machine not to advance any material through it and you will get a big knot instead
Feb 15, 2015 | Sewing Machines
Fabric not advancing
run you finger over the feed dogs under the foot - can us feel them above the surround? if not, you have placed your machine into free style sewing, and the feed dog does not advance the fabric in this mode. Look in your manual and see where the feed dog gets lowered/raised - raising it again should solve your problem.
Nov 23, 2013 | Janome Sewing Machines
Have a janome master craft 3000, just bought it used yesterday. Was sewing fine then all of a sudden it would stop pushing the material through like the needle was dull or something. Now it's doing it...
First do a process of elemination. Unthread the machine, both top and bottom, take out the needle. Place a piece of fabric under the pressure foot, lower the pressure, and depress the foot control. Does the fabric feed? If it does, then put in a NEW needle, thread up the machine, and see what happens. A dull needle won't prevent the fabric from feeding. If the fabric does not feed with no thread, then you have a pressure foot pressure problem, or a feed dog height problem, or a feed step motor problem, or possibly a board problem. If it only has a problem when you thread it up, then maybe you have a burr on the needle plate and the thread is hanging up on it and preventing the fabric from feeding. Check for all of these and if you still need assistance respond back.
Apr 27, 2011 | Janome Memory Craft 3000
Brother LS-2125 Mechanical Sewing Machine Logo
1,665 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
