Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Changing cartridges Have just acquired an Epson CX5500. Has no manual. Black ink low. How do I replace it.? Can't find anything that opens to access them.
    President:
  • 2,110 Answers
    President:
  • 1,073 Answers
I cannot stop the ink cartridge holder to stop in the correct positioo to replace the cartridges on my epsom cx5500 printer
Hello jgw_cansdale,
Welcome to Fixya.com!
If the Ink light (fon3_66.gif) is flashing that means one or more of your ink cartridge is low on ink, and if it's steady it means one or more is out of ink. For Epson printers, there are lots of ways to identify whether your printer is out or low on ink. For today let's just stick with the printer itself.\
Remember: A flashing fon3_66.gif means LOW ON INK, and a steady fon3_66.gifmeans OUT OF INK.
1. Open the scanner bed by lifting it up just like opening a brief case. By doing this you should now be able to see the carrier area this is the area were the ink carrier or ink holder moves left and right,
2. Press the Ink button. Now remember flashing means LOW and steady means OUT of ink.
If the Ink light is flashing, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is low on ink. pressing it again will point to another if you have multiple cartridges that are running low, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
If the Ink light is steady, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is out of ink. pressing it again will point to another if you have multiple cartridges that are out of ink, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
Regards,
Deathschythe33
Aug 22, 2011 | Office Equipment & Supplies
Hi, I have epson stylus cx5500 printer and I am trying to print with only black ink. However the print software keeps complaining about low ink in the colour cartridges. The black ink cartridge is new. Why...
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 03, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX5500- Changing/Installing Cartridge (BIG) problem
they are proper mardy machines only happy when using original epson cartridges
Sep 20, 2017 | Epson Stylus CX5400 All-In-One InkJet...
How to reset 73/91 Cartridges for Epson CX5500
SSC utility is used for resetting waste ink counter, not for ink level counter (chip at ink tank). If you wish to reset ink level counter (chip), you must use hardware resetter, or use CISS chip with autoreset function.
Oct 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Change cartridge on epson cx5500
Please try their website and search for the manual.
Sep 27, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Epson cx5500 prints only with black cartridge???
Yes it will still print with black provided that your computer still detects the colored cartridge tanks.If you are certain that there is still some ink left on the colored ones, take them one by one and shake them hard as if you are trying to distribute the ink evenly. After that, you need to do a test print to utilize the colored inks.
Sep 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
EPSON CX5500 SUCKS ink....
Epson printers will clean the head if the printer is not used for a long period say a week. The only option is to switch on the computer and printer and give a noozle test every 2 -3 days. This will stop the printer from doing a head cleaning which uses the following amount of Ink
Black 1/8
colour 1/16.
Thus if the head cleaning is done 4 times your black is half empty.
thus as the saying goes either you switch on the printer every day or loose the printer
I also had the same problem and now this is what I am doing, and now the cartridge is giving a good amount of prints that too image quality
regards
N.kumar
Sep 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Using colour ink without black ink in Epson CX5500
this cannot be resolved, Epson software is useless it will force you to buy an INK
Jun 07, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Cx5500 all in one and use T0731-4 ink cartridges
If you are using a compatible cart and the printer has twice reported the cart as empty when they are new, chances are there is a problem with the printer. You can buy a chip reseter off ebay for a couple of bucks and try resetting the cart. If the machine still reports the cart is empty you either have dodgy chips on your carts or the printer is having problems reading the chip, This could be caused by a bent pin/contact in the print head cartridge receiver.
Feb 09, 2008 | Epson CX4200 All-In-One PSC Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
198 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
