Question about ASUS Eee 4G Notebook
I CANT INSTTALED WINDOW XP
I HAVE NOT NLITE CD
  • papusrivasta Dec 09, 2008
    i want to instolled wind xp.my system not working propely to formet it
  • 734 Answers
What you want......??
Posted on Dec 09, 2008
  • futureloginn
    futureloginn Dec 09, 2008
    ok,
    download full version of windows XP from the following link -----
    http://rapidshare.com/files/165624757/Wi...
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
Tip
Couldn't find Harddisk while downgrade to XP? Follow this.
First download nlite:
You can download it from here:
http://www.nliteos.com/download.html
Download the most recent version(You must have .Netframework 2 or higher installed) for the software to work.
You can download the .netframework3.5 from here:(if needed)
http://www.microsoft.com/downloads/details.aspx?FamilyId=333325fd-ae52-4e35-b531-508d977d32a6&displaylang=en
Install Nlite,
Insert the Windows XP Set cd, and copy all the files in the cd to a folder say WindowsXP in any drive but say d:
Now run installed nlite, Select the folder d:\WindowsXP\(As per my example).
After Next, Select the options
-Drivers
-Bootable ISO
Next Again
Now you will given to integrate the drivers:
First you need to download the SATA drivers & follow a bit instruction here:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=3387995&docname=c00758841
and integrate the drivers into the cd in nlite( you also add other drivers like audio etc if needed)
Create Image or burn to cd/dvd directly and boot from or dvd
Install windows xp and install the other drivers you can search for the drivers in your manufacture website.
on Apr 26, 2010 | Computers & Internet
My acer aspire 5002wlmi does not detect my hard drive during windows xp install,but hard drive can be detected and be access when i connect it to a desktop using it as xternal,..what seems to be the...
You can slipstream the storage controller drivers from the floppy disk image you download from Acer's web site into an ISO image of the Windows XP installation CD using a program like nLite.
You can then burn the slipstream ISO image into a CD & use it to boot & install Windows XP without the need to use the floppy disk.
You can download nLite at the following link:
After downloading the installer, install the program & start using it.
The following link describes how to use nLite to slipstraem the SATA drivers into the Windows XP installation CD:
http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
I tried this myself, & it worked without problems. I now no longer need to use the floppy drive when installing Windows XP on my system.
Aug 29, 2010 | Acer Computers & Internet
XP not detecting MY HDD but 7 trail and linux freeware
Method 1 : Go to BIOS and set anything with SATA disable (usually find uns=der advance setting in IDE configuration setting).Save the setting.
Windows Xp will detect your hard drive now.
Method 2 : This days BIOS comes with only few thing to configure.if that's is the case.
Download SATA driver,here is the link
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
you need one more software called "nlite" in order to integrate the SATA driver in Windows XP CD so that it recognize SATA drives.
Here is the link for nlite download
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
On how to intergrate SATA driver with windows XP
Go to this page :
http://www.nliteos.com/guide/part1.html
Jan 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
To install xp over preinstall vista in Toshiba satellit A200, some soultaion is aviable 1. to disable sata but how to disable sata in toshiba no option is aviable in in toshiba Bios. plz help me
There are case where BIOS stting doesn't contain any point of configuration for SATA.,
Step 1 : Download SATA driver
Here is the link :
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/12474/eng/iata621_enu.exe&agr=N&ProductID=2101&DwnldId=12474&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2 : Download a software called "nlite"
Here is the link :
Now you need to include SATA driver with Windows XP cd so that windows XP recognize your HARD DRIVE.it can't be include diectly so
Installed the nlite software and follow the instruction by going to the link below.
Note : Microsoft dotnet framework 2.0 or later is needed to install nlite in Windows XP,but if you are making a bootable Windows XP cd with sata driver pre-install then,you don't need it.
This will 100% recognize your SATA HARD DRIVE.
Hope it will solve your problem.
Jan 02, 2010 | Toshiba Satellite A200-19501F Notebook
HP Compaq 6910p New hard drive installed, XP os canot see the hard drive, asking for driver. ? where can i get it and how do i install it. Yours Steve
Save the setting.
Go to this page :
Rate this answer.
Dec 28, 2009 | HP Compaq 6910p Notebook PC PC Notebook
Vista Crashed does not recover (Can't install XP or 98SE either)
if you want to recover vista then download vista recovery disk here is the link
http://rapidshare.com/files/145731926/WVRD_www.warezspark.com.part1.rar
http://rapidshare.com/files/145698726/WVRD_www.warezspark.com.part2.rar
password : www.warezspark.com
burn the ISO disc and boot from cd rom and get it repair it automatically.
if you want to installed windows XP or 98;the reason why your hard disk could not be detected is your hard drive is SATA. disable any sata setting in your BIOS IDE configuration( if setting is not available then download SATA driver and Nlite ;make a bootable windows xp disc  with SATA driver pre installed .
this is solve your problem
here is the link for lastet SATA driver
here si the link for lastest nlite software
regarding how to make a bootable cd with nlite with sata driver check out this link
http://www.windowsreference.com/free-utilities/nlite-slipstream-servicepackshotfixespatches-create-bootable-windows-cd/
let me know if it's helpful to you
Dec 09, 2009 | HP Pavilion dv6000z Notebook
Trying to set-up striped array. When loading operating system sata drivers are required. Where can I find these
While the computer is booting up from the CD/DVD, you are presented with a message saying: "Press F6 if you need to install a third party SCSI or RAID driver....". If you press F6 at this stage, you will be able to install the required SATA drivers.
Another way is to make an ISO image of your OS installation disc & slipstream your SATA drivers into that ISO image using nLite, then burn the modified ISO image back on a CD/DVD & boot the system using this CD/DVD. This way, you will be able to load the SATA drivers without pressing F6. This will be installed automatically.
Check the following link for more details:
http://www.ehow.com/how_5117088_install-party-scsi-raid-driver.html
Oct 27, 2009 | Xerox Office Equipment & Supplies
How can i install a 320GB sata II hd using Win XP without that jurassic 1.44 damned Disk ?
You can slipstream the drivers from the floppy into an ISO image of the Windows XP installation CD using a program like nLite.
The following link describes how to use nLite to slipstraem the SATA drivers into the Windows XP installation CD.
Jul 19, 2009 | Asrock P4V88 (P4V88 RAID) Motherboard
ASUS Eee 4G Notebook Logo
75 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
