Question about Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump...
Jacuzzi Leaking My fitting below my Luxury Jacuzzi are leaking. How do i fix these?
  • phil_m7 May 11, 2010
    Just a couple questions. Can you see the leak? Does it leak when the tub is operating or filling OR leaks only when draining?
    Will reply, Phil
  • 125 Answers
You need to pull the jet body out and then put some 100% RTV silicone around the jet body and the inside of the wall fitting. Once the silicone is in place re-assemble the jet. that will solve the leak unless there is a broken piece on the jet body or the lip of the wall fitting.
Posted on Feb 24, 2009
How to fix a Jacuzzi toilet leaking
contact the MFG's website
Sep 26, 2014 | Jacuzzi Home
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
Leaky Motor
This sounds like it could be the shaft seals, which is a cheap fix.
The Jacuzzi Magnum calls for seal 35-423-1021
You might consider replacing the seal plate O-Ring as well. - 35-105-1120
Aug 06, 2012 | Jacuzzi Pool & Spa
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
Aug 04, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
Jacuzzi espree toilet leaking water from bowl without flushing. water on floor in front.
Hi!Maybe the problem of your toilet is in the mechanism inside the tank that's why its always leaking.Kindly check the tanks fittings of your toilet and replace it if necessary.
Sep 01, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
I have a Jacuzzi brand bathtub/whirlpool 6 years old. One of my jets leaked and created a significant damage downstairs. How can I fix the jet, how can I prevent other jets from leaking? Can I just kill...
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Sep 12, 2010 | Jacuzzi Home
Inlet Valve leaking
I would try PLUMBER'S GOOP (hardware store) on the copper pipe. Remove it and put a liberal amount of goop on the end about a quarter inch back from the tip -- insert and smooth the goop around the connection -- let it cure for 24 hours -- turn water back on.
Charlie
Aug 22, 2009 | Home
Jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Oct 06, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
956 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
