Question about Mitsubishi WS-55907 55" Rear Projection Television
Tv powers on and goes off after about 3 seconds
I have a Mitsubishi WS-55907 55 in. Rear Projection tv. When you turn on the set the tv powers on and goes off after about 3 seconds. I performed the error code operational check and it indicates an error "22" -short protect circuit. Is this something that can be fixed easily? I am not sure what short protect circuit means, or how to go about repairing it. Is it best to call a service tech? Thanks in advance for any responses.
  • 2 more comments
  • hydrazine Nov 14, 2007
    I'm not sure if I have the same problem or not. I have the WS-55907 and when it was unplugged the power went out and only comes on for 3 sec. then goes out. I don't have a manual to see what the diagnosis is, but the symptoms.
  • Anonymous Dec 04, 2007
    My TV (55" Widescreen) had the same issue. I was watching a movie and it turned off. When I turned it back on, the picture didn't come up, no blue screen, just the green 'on' light next to the power button lit up. After 2-3 seconds the TV turned itself off. I have unplugged it from the wall now for 2 days.
  • Shcheglov Apr 15, 2008
    I have Mitsu ws-55907, troubleshooting code 2-2. Previously looked at similar posts. Visually inspected capacitor C9A60-not melted or misshapen. Next, found F9A05 fuse blown(with multimeter). Trying to understand if the suggested IC4B01 needs replacement. Different tvs in the same range have the same troubleshooting suggestions that IC4B01 is the problem. No visible shortage observed on IC4B01. Should i try to replace IC4B01 and the fuse F9A05 ? Or other IC's might cause the same fuse to go out?
    My email dsa_aac@yahoo.com
    Also need help finding those parts online.
    Thanks
    I posted previous post before noticing some sort of liquid on the board. Looks like it could be a coolant from the CRT tube. Any suggestions? Should CRT tubes be replaced? Maybe IC4B01 is ok?
    President:
  • 3,130 Answers
This set has a problem in the horizontal sweep circuit or in the main power supply. Most likely a failed component, and the set shut down to protect the rest of the circuit. If you know how to read a schematic diagram and how the circuits operate, then you will need a good multimeter and an ESR type capacitor checker to find out the short in this set. Sometimes the CRTs(Picture Tubes) will leak the coolent fluid out and onto the printed circuit boards. Also sometimes the convergence IC's can cause this problem, but if that is the case the small little pico fuses will pop also. If you have had no solid state or printed circuit repair experience, play it safe and call in a trained tech. Good Luck
Posted on Mar 17, 2007
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My mitsubishi TV ws-55859 does not turn on. The green timer light comes on and goes off after 3-4 seconds but tv does not turn on. What could be the problem? Help please......
Poor solder connection and Bad STK ICs 2 of them replace Both Big Black IC will have part number on them Call Mats for STK 1-800-628-1118 example
STK392-570.
Nov 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55908 Rear Projection. Doesen't Stay on.
have you tried to access the self diagnosis feature by holding the menu and device/input buttons on the set both in together for five seconds to see if the led will blink a two digit code such as two blinks pause two blinks for a 22 error? Try that and let me know the blink code and i can assist you.
May 21, 2009 | Televison & Video
Powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Apr 28, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65869
This set will require that the power supply voltage problem be fixed...accordianman
Jan 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
Mitsubishi WS-55907 55" Rear Projection Television Logo
245 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
