Question about Zanussi FJS1225W Front Load Washer
SPIN my zanussi 1000 though the washer has gone throught the wash cycle it will not go to spin cycle
  • Zanussi Master
  • 3,463 Answers
If the water has not drained away, then it will not spin.
If it has a filter then check that.
Other possibility is worn brushes in the motor, make sure it is not on a rinse hold sequence..
Check belt has not come off.
There are other possibilitys, but check these first.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
Zanussi aquacycle1200 F1245W When cycle advances-gets hung up on spin.
Hay Jim , sound like you need to replace ccu (main control board )good luck ,APPLIANCES R EN
Feb 26, 2013 | Zanussi F1245W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Zanussi washer machine zwf1621s does a washeing
3 things you need to check : DRAIN MOTOR PUMP ,
LID SAFETY SWITCH & THE MAIN TIMER , hope it helps , AJ
Dec 27, 2009 | Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Frigidare front loader won't spin during wash cycle
Does the washer go throught he whole cycle and just not spin? Or does it just shut down? If it goes the the whole cycle, You either have a bad door switch or a bad control board. Replace the door switch first. Then the control board 2nd. Door switch is a very common problem with these washer.
Feb 10, 2009 | Frigidaire GLTF2940ES Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi 1245w fails to spin
suspect it may not be rotating on wash either. check the moor brushes
Mar 30, 2007 | Zanussi F1245W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
130 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
