Question about HP LaserJet P2015dn Printer
How do i find the IP Address on a HP Laserjet 2015N, i have tried pressing the go button for 5 seconds and this does not work
  • ktnsawant Dec 13, 2008
    Do you have the same Problem
  • 53 Answers
5 seconds may not be quite long enough.. please see extract below from HP web site for the P2015 series.
"On the printer, press and hold the green button for eight seconds, or until the LEDs above the button start to blink. The printer prints out the configuration pages. You will find the IP address on page 2."
Posted on Dec 09, 2008
    Problem Solver:
  • 4 Answers
You are genius solo4665
Posted on Apr 23, 2009
Hi thr, you've to check under the usb port a micro switch for LAN Configurations. press that button to obtain yr printer's default ip address. if its helpful then configure yr printer's lan ip by connecting it through a LAN cable with yr pc,
Posted on Apr 01, 2016
What is the default IP address of hp laset jet 2015n
Press menu then information then print configuration. The second page will have that info on it.
Jan 10, 2011 | HP LaserJet P2015dn Printer
How do I change IP address settings for my HP Laserjet 4650dn printer
Changing the printer's IP address
If the TCP/IP address needs to be changed, the HP Jetdirect can be reset to factory defaults so that it can receive a DHCP configuration from a server (see below). Another method is to use the printer's control panel:
1.Press the green check mark (Select) button.
2.Press the Up or Down arrow to scroll to CONFIGURE DEVICE menu and press the check mark button.
3.Press the Up or Down arrow to scroll to I/O , then press the check mark button.
4.Press the Up or Down arrow to scroll to EIO 1, 2, or 3 (depending on which EIO slot is in), then press the check mark button.
5.Press the Up or Down arrow to scroll to TCP/IP , press the check mark button.
6.Choose Config Method , then press the check mark button.
7.Choose Manual , then press the check mark button. Wait for the display to return to the Config Method screen. A Manual Settings option should now be available.
8.Press the Up or Down arrow to select Manual Settings , then press the check mark button.
9.Press the Up or Down arrow to scroll to IP address , then press the check mark button.
10.Use the Up or Down arrows to choose first byte of IP address. Press the check mark button to save the IP byte.
Repeat for the second, third, and fourth octets.
11.Continue using the Up or Down arrows and the check mark button to enter the Subnet address and the Gateway address.
Aug 18, 2010 | HP LaserJet 4650 Color Printer Manual...
I am unable to reset the admin password on a company printer HP laserjet p2015dn. I treid doing a cold reset by holding the go button while restarting the printer for about 10 seconds and the configuration...
Try to change the password over the network by tyoing the assigned IP address into your browser URL. If you can see the P2015, you should ba able to find the place to change or disable the admin password. If not, perform a Super NVRAM Initialzation:
  1. Turn off the HP Laserjet P2015 Printer.
  2. Press and hold the Go button.
  3. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process, the Attention, Ready, Go lights turn on. Then the Attention and Ready lights turn off,leaving only the Go light illuminated.
  4. Release the Go button. The Go, Ready and Attention lights turn on.
  5. Press and hold the Go button. All lights turn off. During the next three seconds, the Go, Ready and Attention lights turn on in that order, one per second.
  6. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
May 02, 2010 | HP LaserJet P2015dn Printer
How to get printer ip
You can press the MENU button on the Laserjet, on the right hand side of the button to keep to pressing the right side of the button until the Print Menu Map then press the Select button. THIS PRINTOUT SHOWS SHOWS YOU HOW TO NAVIGATE TO THE VARIOUS OPTIONS.
You can select the Print Configuration then press the Select button for a printout of the printer's configuration.
Alternately you can navigate to the JetDirect Menu to view or change the IP address settings.
Jan 17, 2010 | HP LaserJet P2015dn Printer
My network HP laserjet 4Vprinter and ESI 2830 pocket print server suddenly gives an error message "No RARP/BootP Server". How can I fix this?
the information in the link is too long to paste but you may want to look at it.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - TCP/IP, Messages on Configuration Page or Self-Test Page
Get the IP address subnet and gateway address of a computer in the same network.
Usingthe LJ5's control panel, setup a static IP for the Jet Direct using thenumbers you got from the Laptop, except change the last number of theIP to one that is not being currently being used. Perhaps adding 5 or10 to the highest number in use.
Here are the steps to configure the LJ5.
1.Press MENU, repeatedly, until the following message appears on thecontrol panel: HP LaserJet 5/5n/5m and the original Color LaserJet: HPMIO MENU
2. Press ITEM. CFG NETWORK=NO* will appear.
3. Press the PLUS button once. CFG NETWORK=YES* will appear.
4. Press ENTER or SELECT.
5. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
6. Press the PLUS button. CFG TCP/IP=YES* will appear.
7. Press ENTER or SELECT.
8. Press ITEM until BOOTP=YES* appears.
9. Press the PLUS button. BOOTP=NO will appear.
o When using BootP or DHCP, keep the setting BOOTP=YES*.
o The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
o No other TCP/IP configuring is necessary.
10. Press ENTER or SELECT.
11. Press ITEM. IP BYTE 1 = (value) will appear.
12.Press the PLUS button until the value of the first byte of the IPaddress appears on the control-panel display. By pressing SHIFT and thePLUS button, the value will decrease.
13. Press ENTER or SELECT.
14. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
15.Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=),syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=),and timeout (TIMEOUT=).
16. Press ONLINE. Print a self-test page to verify the IP settings.
17. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
else: have the printserver reinstalled
www.nls.com/common/pdfs/v307n10.pdf
Nov 24, 2009 | Extended Systems Pocket Print Server
Resetting network settings to default on HP 2015n
Enter the ip address into your we browser annd reset in the options
Feb 03, 2009 | HP LaserJet P2015dn Printer
Laserjet p2015dn i am trying to set it up and i can not find the password to access the config menu
Hi in LJ P2015 there is no way to set-up password.
Press and hold download green button for 6 to 7 seconds(Not more than 7 seconds) and release it will print self test configuration page on third page netwrok configuration page three is a option called IP Address put that IP Address in the browser it will open printer page and you will be able to browse the printer.
Dec 29, 2008 | HP LaserJet P2015 Printer
Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Sep 08, 2008 | HP LaserJet P2015 Printer
HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet P2015dn Printer Logo
14,330 people viewed this question
Seeker5211
Seeker5211
