I can send a fax on my lexmark X5070 but I can not receive anything
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Just check fax receiving mode .put it at fax only mode.you will receive the fax .
Posted on Dec 17, 2008
I get a remote fax error when trying to send a fax...i have a Lexmark X5070 all in one printer/fax
The problem could be due to the quality of the telephone line connection. Try to resend the fax.
Lower the transmission speed. Follow the steps below:
  1. From the printer operator panel, press Fax mode.
  2. Press the menu button.
  3. Select Fax Setup.
  4. Select Dialing and Sending.
  5. Select Max Send Speed.
  6. Lower the speed to 9600 bps.
  7. Press check button.
Try to send a fax to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
How do i send a fax
Please refer to the Lexmark X5000 Series User's Guide for the instructions on how to send fax. If you're using Windows, you can view on your computer by going to the Start menu ? All Programs/Programs ? Lexmark X5000 Series ? User's Guide. If you don't see it, you can download the printer's user's guide from the Lexmark website for free. Just click on this Lexmark X5070 User's Guide. Thanks.
Nov 22, 2010 | Lexmark X5070 InkJet Printer
Turn off ringer on my lexmark x5070
To turn off the ringer on the Lexmark X5070, go to Fax Mode then press Menu > use the arrows, choose Fax Setup then hit check > use arrows, choose Ringing and Answering then hit check > use arrows, choose Ringing Volume then hit check > use arrows, choose Off then hit check. To re-enable the volume, follow the same path. Hope this helps.
Jun 27, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Fax driver for Lexmark X5070? Where would I find one?
Hi. The fax driver for most of Lexmark printers are usually found only in the installation cd that came with your printer. Just run the installation cd in your computer and make sure to include the fax software/driver. Good luck!
Mar 24, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Unable to receive fax data, i have it on auto anwser and fax mode. sender only gets ringtone. land line is connected to fax mach. please advise.
Test by sending fax to 1300 688 999. Results will be faxed back. Automated service. Cost of local call.
Ring your fax from your mobile when you are next to it and hear it ring and answer.
ADSL filters in place???
Nov 17, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
While sending fax i get an error message remote fax error? what does this mean
Sounds like a problem with the receiving fax machines phone line. Try send to another fax. If it is still doing the same thing, then the problem is in your line.
Jul 24, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Cannot receive faxes on Lexmark x5070 All in one
Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option  saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted....... U will be able to send and recieve faxes..... Thanku.............
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
43 people viewed this question
jasbo
jasbo
